Thanks again Abrax. For my Aya Ds dac I decided to dump the dc blocking caps which got in the way of SQ regardless of what caps I tried. Suddenly one day it dawn on me, what about using a line trafo, out of curiousity I found a 600-600 ohm trafo on ebay which could handle some dc & seller stated its measured well. It was a no brainer for me to try cause I bought them at $18 each. Well the rest is history, couldn’t believe how much better it sounded but I too had to re tweak the ps of my Aya. Killed 3 birds with 1 stone. Low cost as compared to audio caps, dc blocking & low pass filter to smooth out the Nos sound.
Cheers
Cheers
Oh you meant a p channel current source loaded source follower. Funny I never though of that, but I never design anything with a single rail so it's not something I would really have though of anyway due to my hatred of caps 😛.
I only ever use single rails these days - two power supplies is just double trouble. Besides single rail suits balanced very well - no current needs to go to GND.
@sumo - I've only fairly recently been noticing the sound of caps. It was the output caps of that SE buffer which first drew my attention to cap sound, so I'm a relative noob here. I've not tried my own trafos without series caps to block DC but I might try a servo sometime....
Yes Phase that’s true also it’s a combo of parts that takes whatever we’re building to another level & that’s the reason that I do use 1 brand or type of caps on my projects.
Line conditioners does help too. Me my only experience is with Jon Risch Ac conditioner but it will only work optimumly if you follow Jon’s recommendation of loading the conditioner with a 100 watt light bulb or resistor which I found that many have forgone. Now I only use the first stage of this conditioner on my build, it does help a little in cleaning up AC.
Cheers
I do that too with a resistor load near my ac filters. Got the tip from a ham radio site, sometimes experience beats endless simulations.
Tried a (15w) bulb at first, and when it worked, I ordered some power resistors. It definitely helps to improve each stage as much as possible and not rely entirely on leverage schemes within the rest of the circuits.
I will search Jon Risch to learn more about what he’s done as well, thanks for the tip.
Edit;
I had seen some of the Jon Risch work, but had already built mine at that point..
Sumo, did you get an isolation transformer ever?
Hi Abrax
Yes you should give it a try. Don’t think the servo will bring the same results
as trafos, important is do not use the little ones like for mic etc.
I wasn't thinking of using a servo instead of a trafo, rather to allow me to drive a trafo without a series C. My trafos do tend to be little ones (17mm sided cube is a popular one, EP17 cored) but I wind them myself so hopefully they're fit for purpose 🙂
So I currently have four marks against the need for an ultra low impedance supply on the analog portion of a dac.
1: They utilize balanced signal currents so there should not be much if any ripple current from the output section of the dac making its way into the supply.
2. Last time I did an experiment on the ESS9038 checking for the audible differences between using only 1 phase and leaving the other phase disconnected and grounding the other phase to V-ground I did not hear a difference in SQ.
By leaving one of the phase disconnected the current through the supply is no longer balanced and therefore the impedance of the supply actually matters.
3. Even with a varying supply current, the currents that are output are so small that even with a bad regulator the voltage variation of the supply will be practically nothing.
4. Ultra caps and batteries are consistently considered to sound better than regulators as dac supplies even though they have higher impedances than good regulators.
Your observation no.4 suggests that there's another mechanism to consider - power supply distortion. A supercap, being a passive component isn't going to generate any distortion when asked to eat ripple on its output but a reg almost certainly does.
My thoughts exactly. But at the same time. An ultra low noise regulator will also effectively be pure DC. I've never seen dac ripple on my scope.
The reason that you need a series C before the trafo is because your trafo can’t handle DC Abrax. If you can null the dc offset at the dac so much the better. Having a bigger trafo has it advantages. For 1 you’ll have much lower dcr the other efficiency of transfer is far better.
Its like a bigger uf cap vs smaller cap. Not sure if I explain this correctly though. lo but I think you’ll understand.
Cheers
Cheers
Nulling the DC at the DAC won't cut it because I have MOSFETs between DAC and trafo. Their threshold voltage drifts with temperature - so I need a servo at the buffer stage.
@hellokitty - a scope isn't a good choice for looking at ripple which is going to be of the order of a mV or less. There will be a fair amount of HF noise (CM noise perhaps) so you'll not be able to pick out what's in the audio band. Suggest recording the ripple with an SDcard recorder and examining the .wav file in Audacity where you can FFT.
Aaah okies I understand now Abrax but how much drift is there, if your trafo can handle dc, you’ll still be able to get away without series C. Worth a try
Transformers are by far the most imperfect medium of signal transfer with a long list of problems. No need to make it worse by running DC through it or adding caps.
If transformers have any saving grace it would be their distortion, not their performance.
Well such disagreements will always exsist Hellokitty. Goes for tubes vs Ss etc but at the end of the day what sooths the ears most is what matters regardlees .
Cheers
Cheers
You seem 'blissfully' unaware of issues in regards to CM noise. Trafos are unsurpassed there.
@sumo - I can gap my trafos to withstand DC better.
Go for it Abrax, who knows you might be in for a surprise. I’ve seen the pics of the trafos that your using if you gapped & it works well for your set up then the next move is to build a bigger trafo.
Cheers
Cheers
Opamps can do better than transformers in CMRR and CM distortion in dacs is not audible IME.
CM things cancel out at the load if utilizing balanced amp anyway.
Also don't misunderstand when I say transformers are bad.
Euphony is the reason started I learned electronic design to begin with.
Euphonic distortion and high performance are on separate sides of the coin.
Btw Abrax, you’ve been living in China for quite sometime now, so I presume know & understand the art of Tai Chi ? Look deeper into it, understand it’s core principals & apply this to your audio projects
I went to TaiChi classes before I came to live here. I understand some of the philosophy behind it yeah and have been applying 'wu wei' to my designs and postings on DIYA for many years 🙂
- Digital Line Level
- Low noise regulator for DAC & clock
