Noise, both acoustic and electric, would be a problem.
I have some equipment that might do it, though. Which graphs do you want to see?
Mods - might be best to split this discussion to another thread since it's not particularly pertinent to the original post.
Chris
Chris
Matt,
Thst is an interesting challenge. It is one of the key things needed to measure DDR, but low level in the presence of a more normal signature.
One can ask lots of questions, one woul be: the “big” response measures flat, but what is the “little” FR? What is the “little” FR when measured with the “big” response.
An anechoic chamber would be required, and possibly something like Microflown.
dave
dave
Unfortunately not (in speakers at least).
Some have made a 1st stab and gotten nowhere.
I would be very happy if someone did figure it out.
dave
dave
Then you can't know if the big FR is or isn't modulating the little one in some way. I don't see why it wouldn't be measurable, in theory.
I've had a quick look in the mic locker. Candidates include:
- SE4400a - large diaphragm condenser, 25mV/Pa, 16dBA noise
- Beyer MC930 - Small diaphragm condenser, 30mV/Pa, 16dBA noise
- AKG C3000 - Large diaphragm condenser, 20mV/Pa, 18dBA noise.
- Beyer MM1 - Omni measurement mic, 15mV/Pa, 26dBA noise
- A few dynamic mics, but with 1/10th the voltage output.
Looks like the MC930 wins for low level measurements - joint lowest noise figure, but more electrical output means the mic preamp won't need as much gain, so lower electrical noise there.
The input device will be a QSC TM30Pro, which is a digital mixing desk which can feed audio to/from the laptop over USB.
I quite like the concept of DDR. I've been trying to work out how to measure it, and it's difficult to come up with anything that you can put a solid number to.
Some ideas:
- Play pink noise, run a frequency sweep at a lower level. Record with/without the sweep with the same section of pink noise, use software to cancel the two and you're left with a frequency sweep extracted from the noise. Analyse in REW.
- Same idea, but low-level music. Extract the music for subjective evaluation.
Instinctively, a driver's masking of low-level details ought to show up in frequency response sweeps, perhaps as higher harmonic distortion. While harmonic distortion and inter-modulation aren't directly linked, it's difficult to imagine a driver producing one but not the other.
I have the equipment and time to make a reasonable go of this, so if anyone has thoughts on the signal processing and methodology, I'd be interested to hear it.
Chris
Some ideas:
Chris
In theory it is, but super tricky.
IMD would be a side-effect, but not what we are interested in seeing.
dave
dave
Aren't they both due to the same non-linearities and as one increases so will the other?While harmonic distortion and inter-modulation aren't directly linked, it's difficult to imagine a driver producing one but not the other.
I'm hoping the right equipment will help with that.
What're your thoughts on this, as a test method:
- Play pink noise out of the DUT
- Record that
- Play test signal + same section of pink noise
- Record that
- Subtract the two recordings, which should result in the pink noise signals being cancelled out and the test signal should remain.
It seems to me that a perfect DUT would recover the test signal perfectly, while a device which innately masks low-level signals would also mask the test signal.
I just can't decide on a good test signal.
Something like a sawtooth wave might be useful - lots of harmonics, and a cyclic signal. I suppose you could then directly calculate the distortion level from there.
Thoughts?
Chris
Pretty much the same algorithm Pano failed with.
Pink noise is random noise. I doubt it will subtract out.
dave
dave
how about a recording of human speech played at a suitable level -amplify and highpass the recorded result then listen for intelligibility ? is that too biased towards FR?
That would be me.Some have made a 1st stab and gotten nowhere.
- Full Range
- Low level FR measurements?
