Hi folks,
I'm looking for a sinewave generator driving a step amplifier for my inductance meter with the following requirements:
-Not necessarily enclosed, can be a PCB or kit. I'll integrate the generator within an inductance measurement rig.
-Frequency range: 10Hz up to 1kHz, adjustable. The frequency can be fixed, such as steps of 10Hz, 20Hz, 50Hz, 100Hz, 200Hz, 500Hz and so on. No need for small steps.
-Temperature stability. This is where I'm having trouble with a cheap chinese board featuring a XR2206 chip. The output tends to shift in amplitude and frequency at it heats and settles up.
-A figure of 0.5% THD is plenty enough.
There's always the option to just purchase a high quality function generator. However, considering I'll be integrating and only using it for an inductance meter and I rarely work with MHz signals, I don't find the sense of it.
Use temperature stable parts for the timing capacitor and resistor to fix the wandering frequency problem. E
I believe it is the chip itself, as values instantly begin to drift when I aim a small blowtorch towards it's package.
I'd use several single-frequency Wien bridge oscillators. The XR is not intended for precision use.
https://forum.digikey.com/t/wien-bridge-oscillator-construction-and-performance/37970
I have this
https://www.sglabs.it/en/product.php?s=rohde-schwarz-apn62&id=1142
It is complete, very fine
Walter
Walter
Thank you, Rayma. I love simple minimalistic solutions, because they're easy to repair and sometimes, stuff does blow up. Considering I need a few values of frequency only. Although I quoted up to 1kHz, I've only used 200Hz one of a hundred times. I would be more than content with 25, 50 and 100Hz, by building three separate PCBs.
The project is basically an LM1875 amplifier feeding a fixed amplitude and frequency voltage into a step-up transformer to generate a variable voltage up to 200V. That way, transformer cores are excited enough to give the realistic inductance reading. Flux density can be adjusted via the amplitude and not necessarily the frequency.
Using a PTAT current source in a tri-wave oscillator along with a sine-wave shaping circuit (Courtesy: Adel. S. Sedra, Kenneth C. Smith, Microelectronic Circuits) would give stable low distortion sinusoidal waveforms at any frequency. The oscillator capacitor can be any stable kind like polyester, polypropylene etc. and switching between different capacitors would give different frequency ranges automatically, much like function generator.
I think many here will be interested in your complete project.
Read the data sheet of the 2206. At 20 ppm/Deg. C is better than most analog circuits and a lot simpler and cheaper. But if you need to use a blowtorch....
The original 2206 was good but it hasn't been made in forever. The ones you can get now are clones that can't be trusted for anything. That said, try changing the timing cap as mentioned above, to something stable.
I found these using a Google search for Texas Instruments Sinewave:
Texas Instruments publication SLOA060
Texas Instruments publication snoa839
Texas Instruments publication slyt164
Texas Instruments publication SNOA665C
If building a lightbulb feedback network oscillator, is lowest current possible roughly a correct guideline? There are 20mA bulbs at our local suppliers, at voltages between 6.3V and 28V.
This may be an adequate solution: https://www.ebay.com/itm/3566216412...ine+wave+generator&sacat=0&relatedSearch=true Cheap, pretty low distortion. I have one and itts relatively trouble free. Should be adequate for a bridge source. Building a sine wave source only makes sense if you need really low distortion.
- Design & Build
- Equipment & Tools
- Low frequency signal generator
