Low activity here, is there any other forum that you can recommend for acoustic issues?
Polar pressure map ( recorded, measured) is a prerequisite to locate the acoustical treatment if you expect them to be effective.
And each room is different so the room distribution can't easily be predicted. This is why there is sometime so much difference with simulation, they are usually based around the assumption your walls are reflective at all freq and it is rarely the case ( except within a bunker maybe).
The type of materials used in the built plays a role too: a typical plasterboard wall ( metal rail frame) can act as an low freq absorber too...
Celef you should read Earl Geddes research about multisub. It should help you understand why it is sensible.
Earl's approach to multisub is not the only one and other exists too ( dba) which can works as well or more to your preference. But principles behind them are well explained by Earl.
http://www.gedlee.com/Papers/multiple subs.pdf
Reactions: simon dart
@celef all rooms have strong distributions of cancellation and reinforcement at low frequencies that come from room geometry. Your room dimensions don't look particularly troublesome at a glance, there aren't strong mathematical relationships between dimensions that would lead to coincident reinforcement. You can't just throw absorbers at this problem and expect to solve it in my opinion. Sound does not bounce around at these frequencies, the room is modal. Try and imagine 3D pressure maps filling the space that change with frequency. Those peaks and nulls in the pressure distribution don't change unless you hit them with mathematical precision. Forgive me but you are so much more likely to succeed if you don't excite the worst of them in the first place. Get the placement right. The most important step in setting up any system is to place the speakers and the listening position at points where the interaction with room does least damage. Start with placement always, direct your efforts there and you can get much better results at zero cost.
yes, i think too that i could do better by a different placement, but for now i want to try to get the best of my current placement. the reson for putting a lot of absorption in room corners is the high sound level build up at these locations, if i could get my absorbers to swallow the excessives freqencies i think the overall sound quality in my room would be better
The issue with small rooms ( and most of our domestic rooms are from an acoustic pov) is the ratio of acoustics treatments needed/room's volume is not good for something other than a dedicated auditorium.
I'm not saying it's not usefull, i just say for it to be able to 'solve' the issues you face you need a LOT of them and so availlable space within the room is really impacted.
This is especially true when porous absorbers are used. Depending on their type the location can be critical to efficiency too, which is another obstacle for domestic room.
i am willing to hear how you would do if you where forced to use only friction absorbers alone in a room like mine, i do not mean in detail ofcourse but in general 🙂
Yes a AVA is a nice answer but at 3000euro piece...
I answered Celef: multisub first then acoustic treatments ( it'll still be time to see what is possible then).
In my view multisub is easier to try too: you borrow or rent some during a week end, try it see if it solve issue.
If madame have to leave the house negociate a nice romantic evening in an hotel. Works well. 😉
There seems to be a very low interest in room acoustics in this forum, can you recommend another forum that has more activity for this topic?
thank you!
peace
Sorry, but I can't! Room acoustics is a critical part of good sound, but it's not shiny or glitsy. And, it's complicated. You'll be hard-pressed to find hobbyists who know much about the topic. I'm probably lucky to have studied the topic for many years, read all of the pertinent texts, and worked in the field. If you find a good website, please do let us know!
I understand your wish to not move anything but I'll try and make my point clearer. You wont supress your 50Hz mode by just throwing absorption into the room where you can. That resonance is defined by the room geometry alone and how you are energising it. BOTH are placement critical. The correct absorption has to be in exactly the right place for it to be effective. If you put an absorber in the null of a room mode it will do absolutely nothing.
I can highly recommend this book:
Floyd E. Toole Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms​
this is useful to try and get an idea too
sengpielaudio.com/calculator
i understand
thank you, i will let you know if i find one 🙂
good points, but where would you recommend me to place the absorbers for the 50 hz peak that is due to the front and back wall distance? it seem when i simulate my room in rew i can reduce this peak by either using thinner and less effective absorbers but on both front and rear wall or a single massive absorber on either wall, but do thinner absorbers really work together this way when spaced so far away from each other?
I can't really advise because every detail matters, and I have no practical experience of using absorbers to tackle bass issues. I've only ever solved issues like this with loudspeaker placement. I have plenty of bookshelves in my listening space which are great diffusers and one absorber on the back wall behind the listening position. If you are doing simulation in REW then I'd go with it! Good luck.
Unfortunately quite a few really knowledgeable people don’t participate at Gearslutz (Gearspace) any longer. My guess is it is because it recent years topics on Studio Building / Acoustics have been ”diluted” by those who want ”quick, easy and cheap fixes” for their rooms. Often there are no such fixes, especially in small rooms. So, experienced people got tired of answering the same questions over and over. There are some very good threads but you have to go back several years. Search for posts from people like Boggy, Jens Eklund, Rod Gervais, John H Brandt, Hannes, SAC.
A fairly new forum which has not been ”diluted” that much yet with rubbish is https://digistar.cl/Forum/viewforum.php?f=3
In any normal sized room there is no diffused sound for ”lower frequencies”, so there is no reverb and room modes rule. Decay time for a certain low frequency depends on listening position and speaker position. With a DBA setup the deacy time can be lowered at the listering position substantially. In my all concrete bunker its is around 340 ms non smoothed. If I check the largest peak about 10-12 dB at around 41-42 Hz at the very worst position (centre of room), the decay time for that bump is only about 400 ms though. If I move my position the decay time will change of course as it is the 2nd length mode.
