Anyone know where one can buy or order a decent circuit board for the TDA 2050 chip? I have 25 of these chips.
I've been searching and I have found numerous pictures of designs but no boards except for elliot sound products and 15 bucks a board plus shipping to Ohio USA is more then I would like to spend.
I bought 2 assembled TDA 2030 2.1 amps off ebay and they sound nice but you can only use a 12 volt supply which drops the power down.
Thanks,
Thanks,
They are compatible with LM1875 and TDA2030 or 2040 , that should help you broaden options.
I suggested a stereo one in an LM1875 thread.
Search for it.
Search for it.
pcb
i'm now using an amplifier with these pcbs and work really well with a supply of 18 - 0 - 18 ~ and in continous 25 0 25
DIY TDA2050 Hi-Fi Chip Amplifier (chipamp)
You can use LM1875 boards for TDA2050. Pin out is identical and so are supply voltages etc. Gain for the TDA2050 must not be lower than x 16 ! Most boards show a gain of around x 33.
Thanks I will begin the search for LM1875 boards.
It would be quicker if I sat down and learned a PCB program but I have very little patience for PC programs.
Since the TDA2030/2040/2050 and lm1875 are only 5 pin chips the pcb"s are really easy to design , you can probably design one in about 30 min and have a home etched board a hour later .......
Cheers
You may even open this factory suggested PCB in any graphics program, resize it so it prints to proper scale (so parts and specially the IC fit) and then print it on regular paper with any printer.
Then you put a piece of transparent/tracing paper and hand trace it with a black ink pen.
Presto! You have a 1:1 PCB artwork.
You can even draw it straight on copper with some water resistant "Sharpie" pen.
Google "handmade PCB" or search You Tube.
Depending on technique you might have to mirror the drawing or not.
I found some boards. I'm not ready to start making my own PCB's, if I knew more I would attempt it.
Got an email from Deep Singh email is audioampdiy@gmail.com.
I found him reading some older posts on here.
hmm, no reply back so I guess I'll be buying some from ebay after all
I bought 1 each of these boards
LM1875 Dual Channel DC Output 5532PRE Amplif PCB DIY | eBay power supply filtering, pre amp and stereo amp
Amplifier PCB TDA2030 LM1875 Low Cost Chip Amp Board | eBay one of these and another almost identical board from china but didn't save the link due to this one is from the US and price difference is miniscule
2 1 TDA2030A NE5532 18WX2 36W Stereo Pre Amplifier Amp Board Kit Magic Sound 12V | eBay 2 of these, Had one working but pushed the sub side too hard with a 4 ohm woofer and burnt a chip, I have other 2030's and 2050's
I think this would work ? I have used them for other 5 pin power op amps .
Buy Audio Amplifier Printed Circuit Boards TDA2030 PCB audioamplifier,10W 79x63.5mm One Way Circuits M12653 online from RS for next day delivery.
thanks for the link, I'm waiting on some warmer weather since I work in my garage. I did order all of my capacitors and resistors and bought 3 good size heat sinks.
Just need some 50 degree days.
Celsius and Fahrenheit .
16 C = 61 F
28 C = 82 F
To a good approximation .
451F = burning point of paper ( it is said ) .
16 to 28 C is a typical British summer .
16 C = 61 F
28 C = 82 F
Hi jxisix , its deep from audioamp. I am going open source, I can share the pcb file with you and you can get them made in your place. Sending them by courier may not be cost effective.
Well...er...I know I'm going to get myself into a fistfight here, but how about the perfboard that Radio Shack sells? Others sell perfboard also, but the shack's is about the least expensive--surprising as that might be.
In my experience the wire lead length on components is more than long enough for connecting things up. I've never had to use any additional wire except for off-board connections.
Actually I prefer the pcb's, it is easier on my memory since the right parts are silk screened there.
I am almost finished with the 2.1 board I bought, it already had the components on it just had to find a decent enclosure. I am using an old A/B Parallel Port box. (btw the inside was shielded with something that measured 10 ohms with the meter so I had to paint the insides too)
Saturday I lined everything up, (after several nights of try it this way)
made a new faceplate out of 16 gauge aluminum, drilled all my holes then painted everything.
Only thing left to do is drill and tap the holes in the heat sink for the chips.
Since this is a garage amp the RCA jacks will be on the front panel, I get tired of having to turn my present amp around to change the inputs.
I would also like to include a 1/4" guitar jack, just haven't figured out what type of switch I should use so that the guitar works on both L & R channels.
I am using a radio shack 12.6-0-12.6 2 amp transformer, which from everything I have read is under power voltage and amperage wise, it will have to do till I buy a 18-0-18 4 amp.
Speakers will be a pair of 4" voigt pipes I made (89db@1 watt) and a 15" 8 ohm eminence woofer for the sub. Not a true sub but it should be passable.
I think the other 2 boards I would like to try to bridge them using 2050 chips, I don't really need a sub in my garage.
Sorry about the lack of pictures, I'll take one when finished and upload it here. My garage computer is not finished yet and when I'm working I forget to use a camera.
- Chip Amps
- Looking for TDA 2050 circuit boards
