To be used with Eichmann silver bullet plugs. I found some Furutech ag coax already but I do not know if that will fit. I need 1.5m and would like to keep the cost under $100 usd (just for the cable). Any suggestions?
Don't waste your money?
Silver coax will do one of the following:
(a) nothing
(b) small reduction in attenuation at UHF and microwave frequencies, which is likely to either:
(1) do nothing
(2) make jitter slightly worse
(a) nothing
(1) do nothing
Hmmm...why do you suppose companies such as Wireworld and Kimber use silver materials in their digital cables then? I assume your increased jitter theory applies to silver plated occ and silver connectors too, right? In your opinion how can I make the best possible sounding/lowest jitter digital IC?
I have no idea why people would want to use silver for relatively low frequency connections. You will have to ask them. Might be driven by marketing rather than engineering?
I don't know about 'best possible sounding' but for lowest jitter you want coax which has the right characteristic impedance (which means ordinary decent stuff, not cheap CB feeder cable or expensive 'audiophile ripoff' stuff either). Accurate terminations will help, but that is down to the equipment designer. In 1.5m you can't do much harm.
Go BNC connectors, go nicely crimped BNC cables, make sure everything is 75ohm.
Unfortunately, I need RCA's on both ends. I suppose I could use adapters, but they may change the sound a bit. <shrugs>
At the moment I'm leaning towards a manufactured Mark Grant G200HD. It's 100% copper and reasonably priced.
Woah... that's a great vendor. Thanks!
RG-400 Runs about $2.50 per foot and is Silver Plated Copper.
It's nice and thin with a braided center conductor.
I have stock on some for $1.25 per ft
listed on my wire page at Apex Jr.Home Page
RCAs are not constant impedance, unlike a well-made BNC, so the quality of the cable becomes almost irrelevant when compared with unavoidable reflections at the plugs/sockets. Should not be a problem, but absolutely no point in worrying about the cable when you have to use the 'wrong' connectors on the end.
Quick question, RE: the earlier link, how do the bass frequencies know how togo downthe tin plated copper and how do the highs know to go down the silver plated wires. just curious.
For digital signal transmissionas DF96 stated, impedance mismatches are much more serious to signal degredation than whether the wire is copper, silver or silver plated copper. For Mil spec cables silver plating is for temerature range of the cable, not for any signal improvements.
Any transmission over coaxial cable is carried via the center conductor.
The outer shield is just that, A Shield, it does not carry any signal.
The shield is an integral part of the cable that serves to help set the impedance of the cable.
Nope totaly wrong, the outer shield in a standard co-axial carries the return current, the return current is as critical as the normal signal especially in digital.
Yes, the inside of the shield carries exactly the same signal current (but inverted) as the centre conductor. That is how coax works! In a well-made coax, properly used, the outside of the shield carries no current.
I work with coaxial cable on a daily basis.
I can take two radios and connect them with the removed center conductor of coaxial cable the transmitter of one to the receiver of the other.
I can generate a 1khz tone that is carried on 155MHz with 2.5Kc of deviation and there is no measurable loss between the two radios even with 50' of coax center without the shield other than the cable loss itself.
If I add the outer shield I get the same results.
The same holds true with my preamp to amp, I have only connected the center pin on the RCA's and did not lose anything from not having the shield.
Look up digital or analogue signal transmission, there HAS to be a return current path.
You must be completing the loop some other how, cos current wont flow down wires without a return path, so it will find one. Your pre-amp toamp is probably using the saftey earth connection, rf uses the real earth I believe as a reference plane.
So the signal will find a return somehow,otherwise it aint going no where.
At such frequencies the return currents find their way home by their own - usually thru air - parasitic capacitances or RF emissions. The "shield" just helps the currents to return, making-up the least impedance path which they tend to follow.
- Design & Build
- Parts
- Looking for silver digital coax
