Could it be not better to design from an avaliable B&G RD 50 ? with a higher XO that the RD75 ! There are fast pro driver around 12" (12P80nd/v2 for instance) to try to match the transcient of a planar with a classic cone driver (with low cone mvt and high electrical damping) ?
floor to ceiling line source is different, shorter won't be a line source to as low a frequency, won't illuminate same height at higher frequency
stacking the 1 m will have a gap in the middle
surprising that there wasn't already a RD-75 knockoff available - probably not the yearly volume to justify 2 sources before but now there are loudspeaker manufacturers needing any source for them
Could it be not better to design from an avaliable B&G RD 50 ? /QUOTE]
Available where?
Hummm I can't find anymore the rest of the RD serie 😱 I thought they just gived up the RD75 for DIY distribution !
Too bad !
Too bad !
Nope, all of the B&G stuff is gone (at least for DIY). You might find a pair of lost NEO3's or NEO8's is you're lucky..
Edit: for one ones interested, here is a pair of RD50's on ebay: http://www.ebay.nl/itm/BOHLENDER-GR...magnetostat-/252102018587?hash=item3ab273861b
Why a Neo 3 should be better than todays AMT or ribbons ?
Yes Neo6... but it low end spl : never saw a measurement in a box with a flat enough curve ! This driver seems not easy to play with despite the dreamed 600 hZ to beginn with ! (Would like such a planar with aflat curve from 600/800 hZ to... ) Unluckily AMTS are too thin sound or distorse in those range... I lurk sometimes on the diy ribbons on this planar section 🙂
OP here, ty for all the feedback to date. Turns out I am not the first person to ponder using AMT's in a line array. Meet the Steinway Lyngdorf LS https://steinwaylyngdorf.com/products/model-ls-concert
Turns out that this configuration has been well received! Not sure about doing an open baffle though. Will save that discussion for another thread as I would like to keep this one on topic.
Cheers
Derek
Cheers
Derek
I would buy 50 Fountek FE85 3" Full Range Speaker Driver, 25 per side in a line array, ~$11US ea from parts express. Sell the Fountek ribbons on ebay.
IMHO, the gains from not having a tweeter crossover will outweigh the difference in freq response between the FR & ribbon above 10kHz.
Having made measurements of the HF wavefront curvature on various drivers while investigating line arrays, I have found that the effective center isn't at the voicecoil, as conventional wisdom would have us believe, but 6-9 inches behind the front of the speaker(although I haven't measured the fountek driver), which means that the comb filter effect for closely spaced drivers is much lower than most people think. If you find that comb filtering in the upper treble is a problem, a simple acoustic lens can delay the wave from the center of each driver so that it is aligned with the driver edge wavefront in the vertical direction. The lens will cause frequency variant lobing horizontally, but that may be of benefit in reducing coherent room reflections. If the location of a wall that your subconscious auditory processing determines isn't the same at all frequencies, your brain will acoustically "visualize" it as being like the edge of a grove of trees(more spacious) instead of a flat surface of drywall(restricted).
Fountek FE85 SpecificationsAn externally hosted image should be here but it was not working when we last tested it.
Fountek Manufacturer WarrantyAn externally hosted image should be here but it was not working when we last tested it.
See Catalog Page
If you go that route, why not go for Vifa TC7FD00-04. It's even cheaper, and measures better..
I wonder what this would do compared to a couple of Dayton AMT's...
The Fountek has higher excursion, efficiency, and cone area. This probably wouldn't make much difference in an amplitude matched A-B-X blind comparison; the money saved using the Vifa would pay for a miniDSP and a bigger amp. Have you seen any distortion measurements for the vifa, like here?
http://techtalk.parts-express.com/attachment.php?attachmentid=31635&d=1355711192
One could also use the fountek FE87 - on buyout @ $7.10 - and get 5-8 dB boost above 10kHz (good for my 65 year old ears &;>)
One could go for the Eton Symphony 3" Midrange 3-400 @ $169 a pair (less 10% in 25 pair quantities &;>). Plus you get a 10dB boost above10kHz.
I once heard a customer in a high end audio store say, after auditioning a 1200 dollar (circa 1970) 3-way system, say "these sound really nice; do you have anything comparable that's MORE expensive?" Siegfried Linkwitz, upon asking a salesman how can you justify charging these prices [$68k?] for this speaker that has maybe $5000 in parts? was told "the price is a large part of what our customers are paying for."
Err, I know this topic is a bit old, but for avoiding creating a new one.
Have anyone heard Expolinea MD-2000s? Or at least know if there are somewhere I can hear it? Is it "better" (of course its subjective) than BG RD-75?
I have not heard ANY that sound even close to my RD-75's
Get real its only plastic film with 4 alu strips on betwin some ferrit magnets.
Well... thinking that way all ribbons are.
No the special thing in BG75, is the number 75. It would today be easy to produce a better one. But their is no real marked for it. Most ribbons are short closed back with a transformer.
You're right! One of the main points on it is it being huge.
But if this is the case a array of multiple smaller ribbons drivers would easily be able to overperform it. Regardless of price, do you have any ribbon driver suggestion that can do it with ease?
Also, what do you believe to be the state-of-art midrange nowadays?
Well i make them as diy 🙂. And if you want a long planar, the only solution is diy. I owned the rd50, nothing special.
Please, tell us more!
Any measurement on their performance? May I have a link to any of them threads / video?
I have put some up on this forum. But I use very big expencive neo magnets. If you take a look at carvers planars you will get my point. If can find a Company that can make the holes in a metal sheet. And some neo magnets.Please, tell us more!
Carver AL-III’s. | Audiokarma Home Audio Stereo Discussion Forums
- Planars & Exotics
- Looking for BG RD75 substitute
