cbriere said:the Zapfilter look good.
I need to build it for myself.
I found the schematics but no par values on it
did someone has builted a clone of the zapfilter?
I was working on something quite similar, but have shelved the project for the time being. (Not enough time in the day.) I might be motivated to resurrect it at some point for my scd-777es project player, but for now its asleep..
cbriere said:Hawksford....... schematics available?
please post link,,,,,tks
http://www.essex.ac.uk/dces/research/audio_lab/malcolms_publications.html
I found the schem. of Zapfilter clone,,
http://www.diyaudio.com/forums/showthread.php?threadid=20294
but,
did anyone had succes with this circuit?
but,
cbriere said:I found the schem. of Zapfilter clone,,
but,
It works. It's the exact same as the actual Zapfilter but uses better transistors, so I consider it an improvement.
Hello
I this Thread is very good and interesting learning
I have taken this shuntreg from an old zapfilter (Lcaudio) I know it´s sound very very good, using it in my modified cdplayer.
It gives constant 10V out.
The Shuntreg is supplied like this:
Transformer-> Rectifiers-> serie resistors to set the current flow-> shuntreg -> load
Trans BCP51 take 100mA by it self (sinks)
Can some off you simulate this??
Eks: 15V DC supply, Current to circuits 150mA (100mA BCP51 and 50mA pulled by load.
Kim
Kim
- Digital Source
- looking for All BJT i/v output stage
