You will be using some kind of EQ for the low end yes? No?
Yes. Will be feeding the sub amp with a Behringer 2496.
i have two Infinite Baffle subs w 2-15" subs each.
I blew one of the subs in one of the cabinets. I plan to replace all 4 some time in the future but until then, i need a stop gap cheapo sub to put in one of the cabinets. It wont be optimal but will suffice for now.
BTW... did I mention i'm looking for something cheap?
The Dayton classic 15" is a decent driver for $, you may want to check out the MCM line at Newark Electronics (AKA: Element14).
They are cheaper, have the same Xmax and a higher Qts(typically higher than they're rated too). High Qts is desirable for IB alignment. Go online and find discount codes to offset shipping costs.
