Hi all. Fantastic forum you have going here. Pity I only discovered it now.
Anyway - As a result of a somewhat historic New Year's party I think that I have blown one of my Z-680 satellites' drivers. I have tested other speakers on the same channel and they all work fine. This speaker on all channels (which work fine with the other satellites) is completely dead - no sound whatsoever emanates from it. I have confirmed it is not a cabling issue.
Searching through the forums I have found that Logitech seems to use TangBand drivers and that the specific driver used in the Z-5500 is the TB W3 871S. It however appears different to the drivers in my Z-680's - most importantly that the frame is round, not "squared off" like mine is. I really would like to replace the damaged driver, but am not sure which model to buy - if it is a TangBand. The frame and diaphragm of the W3 926S looks exactly like mine, but the magnet of the W3 871s looks like mine. Does anyone know what exact driver Logitech used in the Z-680's, or what I can replace the damaged one with? Would the W3 871s be OK (the frame would have to be cut to fit the enclosure) or should I go for the W3 926S which would fit without any modification, and has similar (but not exact) specs as the W3 871S? Or is it something else entirely - I have seen an Aurasound NS3-194-8E that looks very similar to my drivers frame and diaphragm, but the magnet is a bit different?
I recently had a dead z-680 sat, turned out to be the tinsel to terminal connection.
Test continuity from tinsel lead to tinsel lead, you should get a little under 7Ω, if you do you can resolder the terminal connection.
If it is blown I think the driver looks like a W4-616S , but it might be cheaper to get a set off ebay?
Hope this helps
James
Hope this helps
James
The speaker in the Z680s is a custom build for logitech I think
TangBand W3-665SC
Diaphram Material: Paper
Surround Material: Santoprene
Nominal Impedance: 8
DCR impedance: 6
Sensitivite 1W/1m 88dB
Frequency Response: 120Hz-20KHz
Free Air Resonance: 120Hz
Voice Coil Diameter: 20mm
Air gap Height: 4mm
Rated Power Input: 15W
Maximum Power Input: 30W
Force Factor, BL: 3.2TM
Magnet Weight: 120g (4oz)
Moving Mass: 1.45g
Suspension Compliance: 1106 MN^-1
Effective Piston Area: .0032 M^2
X-max: 1mm
Vas: 1.6L
Qts: 0.63
Qms: 6.88
Qes: 0.69
Ebay sounds like it's definitely the way to go for a replacement driver.
You could replace the blown satellite with the driver from the centre speaker assuming it is the same(I've taken apart mine before, I *think* it was different) then get different driver for the centre like a 871s
TangBand W3-665SC
DCR impedance: 6
Air gap Height: 4mm
Moving Mass: 1.45g
X-max: 1mm
Vas: 1.6L
Qts: 0.63
Qms: 6.88
Qes: 0.69
Thanks for that guys! Much appreciated
I was kindof hoping that I could just buy a replacement unit like the 871s directly on the net. Obviously this isn't going to be easy since these are custom-made for Logitech.
I have searched on Ebay, but no-one is selling individual satellites, rather complete sets which are not cost-effective. Additionally, living in South Africa is a problem, particularly for shipping costs.
I will keep hunting and let you know what I find
Have you contacted Logitech? I did for a faulty keyboard and they were really helpful and finally replaced it without any problem... Maybe they could give / sell the speaker you're looking for?
Hi again
Have just contacted Logitech support, and they cannot help since they no longer have any of the units in stock.
I have also made a request on EbaY - will wait and see if anyone comes back to me with a positive response.
Again, thanks for all your help and suggestions - I will keep you posted regarding the outcome.
BTW, I also own a Logitech Z-5500 speaker system. I preferred the crisper sound produced by the Z-680's (especially the bass which is less boomy). Does anyone have any suggestions/comments about the 680's vs the 5500's?
You could also try Freecycle Johannesburg
Freecycle South Africa
Bloemfontein-19 members
Cape Town-1137 members
Durban-238 members
East London-9 members
Johannesburg-207 members
Knysna-21 members
Ladysmith-30 members
Pietermaritzburg-121 members
Port Elizabeth-34 members
Potchefstroom-12 members
Pretoria-118 members
James
Durban-238 members
Knysna-21 members
James
the Z5500 bass or more boomy?
geez I thought my z680 was boomy as it was, I stuff socks down my bass port and dial it way down on the controller.
One of these's days I'll redo the enclosure.
I just check the centre speaker versus the other satellites, it's a different driver on my set.
Another option you have is to get the satellites off the Z560s I'm almost certain they are the same drivers. That's the 4.1 speaker set that is the predecessor of the Z680s. If you can even find them brand new they can be very very cheap.
- Full Range
- Logitech Z-680 Blown Satellite
