Thanks I think ive got it not ive posted a pic pls take a look.Have you had a look here section 3 and figures 3 and 4? Bucking Xfmrs
Be very careful, you have to get the phase the right way round or you will be adding the secondary voltage not subtracting it. Use a filament bulb in series with the mains supply when testing.
Correct, join "2"-"3" and measure "1" to "4". If you measure around 260V, you disconnect "2"-"3" and you join "2"-"4" instead (and measure "1" to "3").
Let me hear when you measure around 200Vac.
What we are doing here is the same as if you stack batteries: If you put a 6V battery on top of a 12V battery, you have 18V. If you turn the 6V battery around, the 6V are subtracted from the 12V and you get 6V.
For a transformer, the voltages are not static as for a battery so we do not talk about "polarity" as for a battery but "in phase" or "counter-phase".
Then, it is 2-4 we want. 222Vac is above what we could expect. The secondary was a 30Vac output?
The high value may drop with loading.
Now, connect the new "output" from terminals "1" and "3" (with 222V) to the primary (230V input) of your 30-0-30 transformer. Then, measure the rectified output voltages (with rectifier, 5600uf buffer capacitors and 330 Ohm loads).
Before it was 44.7V, now?
Hi gimpchop,
32.4V and 32.1V seem much better. A slight concern is that there is little consistency between the values you have measured on the 30-0-30 transformer, the small transformer and now the rectified output.
Could it be, the battery in your multimeter is almost flat?
Anyway, now you have seen how you can make a power supply with two transformers that appears to have a useful output voltage. I cannot see the power rating of the small transformer: When you have your amplifiers ready, let them play at good sound level for an hour and see if any of the transformers become warm. Always use a fuse in the primary of the small transformer and remain careful not to touch the high-voltage wires and terminals.
A two transformer solution is not as good as a single transformer solution because you have more idle losses and your voltage will sag more than if you had only one transformer.
When you become rich, buy a better transformer. But until then, you can use this combination.
Good luck with your LM3886 project.
- Power Supplies
- LM3886 power supply
