still working on the innards. when finished it should have 2 12 step attenuators. dale resisters and panasonic caps. i wana play around out of the case to see if a valve buffered gainclone sounds good
gota go shopping😉
gota go shopping😉
Purple glow= a bad figure
Quote: "recycled like most of my parts"
I can see the purple glow, instead of orange in the tube... a bad figure....!! You might have to buy a new tube.......
Use tube dampers, to reduce microphonics.
But nice tube, Amperex brand.....
burn in?
whats a good time for a gainclone to burn in. this ones been running for a few hours now and it just keeps sounding better and better. it had very littile base now it has allot😀
i would like to thank peter daniel for helping me with the aluminum
thanks.....🙂
i just ordered lm4780s fun stuff
thanks.....🙂
Quote: "i was not happy with the tube so i left it out"
How did it sound like when you had the tube on?
it had a warmer sound to it and more base. but it needs more room in the case. do to heat and i didnt want to cut a hole in aluminum for venting the heat. im working on making another gainclone like peters daniels patek and it will have the screen on top. and wood on the sides. 😉
well so good for my test speaker. maybe i turned it up to much😉
smells like guacamole. amps fine😀
- Chip Amps
- lm3875t? or lm3875tf
