hi
Does using a Linkwitz transform have any nasty sonic effects (apart from power/efficiency/spl issues)? thought about using it with a big sealed box with a low Q...
I used the calculator here:
http://sound.westhost.com/project71.htm
and put in these numbers:
Fs 25Hz
Qts 0.2
Vas 276 litres
Vb 120 litres
and got a low system resonance and a low end that begins rolling off above 100Hz - seems like an ideal candidate for correction, but I'm just wondering about any side-effects.
thanks!
Fs 25Hz
Qts 0.2
Vas 276 litres
Vb 120 litres
thanks!
If your driver doesn't have the power handling and Xmax to cope, then you will see an increase in distortion.
pinkmouse said:If your driver doesn't have the power handling and Xmax to cope, then you will see an increase in distortion.
Hopefully it will have, and I won't 🙂
