hi
Does using a Linkwitz transform have any nasty sonic effects (apart from power/efficiency/spl issues)? thought about using it with a big sealed box with a low Q...
I used the calculator here:
http://sound.westhost.com/project71.htm
and put in these numbers:
Fs 25Hz
Qts 0.2
Vas 276 litres
Vb 120 litres
and got a low system resonance and a low end that begins rolling off above 100Hz - seems like an ideal candidate for correction, but I'm just wondering about any side-effects.
thanks!
Fs 25Hz
Qts 0.2
Vas 276 litres
Vb 120 litres
thanks!
pinkmouse said:If your driver doesn't have the power handling and Xmax to cope, then you will see an increase in distortion.
Hopefully it will have, and I won't
