I wonder how Barleywater's Pluto clone satisfies the requirement of "a speaker with radiating wavefronts that project back to point"?
If you quote someone you're obliged to provide references, not me.
Markus this is the internet, not a refereed journal. You could have looked up the papers in the same time it took you to post the request that I do it for you. If I had them on hand I would have posted them, but at that moment it was not convenient. Yes, I think that those are the three papers.
Do you have a source for this claim, or is it in the Griesinger papers?
This is a corner stone of Griesinger's hypothesis.
Exactly, a hypothesis, not a fact. Even if his hypothesis turns out to be of value (and I believe it is), it doesn't allow for the conclusion that spurious cues from other frequency ranges aren't detrimental.
Furthermore he is talking about natural sound sources/fields. Our topic is 2-speaker stereo in acoustically small rooms.
By the way, his papers make a good case for crosstalk cancellation and the perceptions that were reported here.
Vocal tract is a tube, 6 to 7 in long, so it will have resonances higher than 500 Hz, even humming.
I don't think you can get there from here.....
I think you can get far enough there.. try measuring it. 😉
Link? Title?
More than a little annoying, no? 😉
Earl most certainly should have provided a specific reference to his specific claim.
What I like about Griesingers work is that he actually looks at speech and music and not clicks and pink noise.
My woofers are crossed at 500 Hz. If I listen to the woofers only, there are directional clues for sure. But they are weak and they are very diffuse. When I listen only to everything above 500 Hz, the directional clues are overwhelmingly more powerful and precise. Adding the woofers afterwards has NEVER changed the direction of any musical signal for me.
I really wonder if anyone can report the contrary. 🙄
Rudolf
Rudolf
Rudolf
yes. Try *one* loudspeaker only.. 😉
Rudolf
Play a slow sine sweep - the image stays in the middle at all times? Lucky you...
ScottG is listening to a baritone without harmonics. 😱 You are listening to slow sine sweeps 🙄 ... anybody around here listening to real music? 😕Play a slow sine sweep - the image stays in the middle at all times? Lucky you...
Rudolf
Just test tone and log chirps, why would you need to listen to that damned music, it just covers up the sine waves anyway.........
Rudolf
..and isolated test to prove an isolated point.
Sure, I'm listening to music right now. 😉
Something more "real-world" then?
Is your 500 Hz (and below) system dipole (with a decent null at 90 degrees)?
In-room measurement - which shows that below 300 Hz modes are ruling everything.
Rudolf
At two meters? At one meter? At half a meter? At a quarter of a meter?
In any event, there does appear to be quite a lot of pressure loss just below 500 Hz off-axis.
Have you tried rotating the <500 Hz portion with the most extreme condition of pressure loss nearly facing your position (with music)? (..say, 80 degrees - outward or left of left speaker, right of right speaker?) And from there eq.ing it flat from your position?
You poor things ... 🙂... how the majority listens: nearfield, away from reflecting surfaces, direct sound is dominant, and little volume capability ....
Frank
At half a meter. No gating.At two meters? At one meter? At half a meter? At a quarter of meter?
Rudolf
Not what people here want to hear, but precisely what I would suspect.
Yes, it's what I would expect (and have also experimented with), depending on the material. (..and I would include most material.)
He is however asking for something to the contrary - and I've also experienced this. But the conditions to do so are not what I would call "normal" (in the context of stereo).
Hmm, is that what I "want to hear"? That presumes I wanted to hear a particular result - which would be incorrect (at least for me).
Frank
Frank, that wasn't fair. That quote suggests the opposite of what I said.
- Linkwitz Orions beaten by Behringer.... what!!?
