Let's talk about XO above 10K hz & 1/4 WL law
I use the program XDir to calculate lobing at crossover frequencies.
You can get it at Tolvan Data
I've used it to calculate the lobing of my 3-way center speaker, between the planar mid and AMT tweeter. The crossover is active 4th order at 8 kHz.
The lobing pattern is not ideal, I had to reverse the polarity of the tweeter because my ears were in a null at the listening position.
When the lobing pattern is bad, I can recommend a 4th order crossover, it does not decrease lobing, but it reduces the frequency band in which it occurs.
Many thanks,
my everyday loudspeaker has a 4th order tweeter on a second order mid... and I like it very much (tweeter with reversed polarity)
But on that casual design which is a also a first for me, I don't want to spend too much money... find it already expensive and much more than a good second hand, although I am making it for fun and to learn from also a listening try & error perspective.🙄 4th order is expensive on parts with passive filters. I hesitated with the super tweeter cut-off very high, leting the 10F full range in the highs without low pass with a super tweeter. Seems it's a bad idea !
I try to stay with not very much expensive parts - I already had the SS 10F- and cabinetry -I chose already veneered ply for instance that you can see in the picture-
Yes I like Tolvan tools. Do you know please, if in the Edge when you enter the diameter of the driver if it is the full diameter size with the metal frame or the diameter of the cone with half of the surrounds, i.e. the radiating area ?
The best use of any software is when the user can see the boundary between its best information and its limits. Its signal to noise.
All software has limitations, but you will get credible data if you know what the limits are. An experienced designer would never blindly trust software unless they can clearly see where those limits are.
