!!!Lets Finally Assemble A 250w hqi setup!!!!!
Just say no to plexiglass!
poohbear said:
hmmm i got my bulb today, its crazy bright... When i first turn it on i was like... is that it? and then it started getting brighter and brighter, and yeah... it got super bright, it made shadows on objects in the room in the middle of the day with the widows unshaded. After i turned it off it tipped over on the carpet burnt a lil and started smoking. Then i put it in the hole of my projector but didnt turn the projector on only the light. The square projection was visable but dim. Im sure if i use a reflector it will work alot better. But after a few minutes it started to smoke so i turned it off. I think and hope, that it just had some carpet still stuck on it and when it got heated up it started bruning it, and not my projector, eitherway im pretty sure its gonna be way to hot. Maybe i can put a plexy glass seperator inbetween the bulb and the light terminal, then replace all the plastic sides of the bulb area with fans. Damn i dont know... and i also dont know what to do about a reflector i wanted to use the original but the hole in the back is to small.
Sorry to hear about the "carpet incident"... hopefully your bulb's not completely unusable now...
For a heat shield, you're gonna want to use real glass, and probably even tempered glass, but not plexi (or perspex or acrylic... maybe for the case, but it better be cooled well) -- don't want to throw any more plastic into the equation, right?
On the road to a useable setup!
Now that the reflector has been cut to fit around the bulb (my friend's pneumatic grinder and carbide bit made short work of it even though it was over a mm thick), I've continued on to more advanced prototyping.
The sockets and reflector are mounted to a temporary base and the makeshift "chassis" is a cardboard box with an opening cut for the LCD panel. The triplet is mounted on a freestanding cardboard panel, so the only light spoilage comes through the LCD and the edges of the fresnel. Next testing step will probably be nesting another box over the first one with the lens poking out the front.
Screen is just a white bedsheet for now and the photos were taken at night with no additional ambient light.
Hmm... I had two photos from the screen, but they're not showing... Trying again...
I'm very happy with the results so far, but mind you that these photos were taken in a completely dark room at night with only the projector and some light bleeding from the test chassis (not completely enclosed). Visibility during the day is quite another matter -- tends to be very washed out. But maybe as the projector components become completely enclosed and I fabricate a better screen, that'll improve as well.
A friend of mine is trying to help out by finding a better reflector. He thought he might have one from an old photographic bulb flash unit. It'd be a larger diameter and possibly a more efficient design.
The quality of your fresnel plays a huge role with your projected light, so maybe you can test another one?
