Lenard Audio TL software 6th order
Hi. I am trying to put series 6th order bandpass in Leonard TL, and can't figure aut how to do it. I can't figure way to feed both port and driver to next chamber. Parralel bandpass is very easy, but this giving me headaches 😕
Could someone help me? 🙂
I am assuming you wish to build :
If so it cannot be done with LATL
If you are thinking :
Yes it can.
To do properly it must be exactly spot on and I personally would not trust LATL to model it from. These are typically used in car audio competition were only SPL matters and only work for a very narrow range of frequencies.
It took me ~10minutes to rough in the dual reflex bandpass type. Tweaked a bit and did not like what I saw. Tweaked it a bit more, but stopped there. I wouldn't build such a beast today, tho have in the past >25 years ago for another person. They do not exhibit what I would call fidelity and definitely not a box for a beginner to design.
Please read this on the subject... Subwoofer Enclosures, Sixth and Eigth Order/Bass Reflex and Bandpass
