Yes, I have searched and I've seen those who say that solder joints make a profound difference in sound quality despite a complete lack of any benchmarks or test results. There are reasons to use silver solder:
1. Higher melting point
2. Environmentally friendlier
I have used lead/tin solder on a few diodes that got so hot that they desoldered themselves. Silver/tin solder would probably have helped in that case. I know silver and lead have different resistances and capacitances, but nothing drastic enough to change the way audio sounds. If it was so profound, maybe you guys could post some frequency response charts from your amps and quit using words like "bright" and "muddy". It's not like the audio frequency spectrum even comes close to FM or even AM radio. If lead solder is used in RF circuits, what's the big deal in the AF spectrum?
Solid Snake said:I know silver and lead have different resistances and capacitances, but nothing drastic enough to change the way audio sounds. If it was so profound, maybe you guys could post some frequency response charts from your amps and quit using words like "bright" and "muddy". It's not like the audio frequency spectrum even comes close to FM or even AM radio. If lead solder is used in RF circuits, what's the big deal in the AF spectrum?
I'm with you 100% here. I was involved in a debate about this a while ago. I made many of the same arguments. What usually happens is that the channel goes quiet, or those who disagree with you simply ignore you or talk around the issue.
In the thread that I was reading/writing about this subject, no one, at any time, was ever able to produce a single shred of evidence that would show why silver or other exotic solders would make any sort of audible difference.
Let's transport this thread over to audio asylum and throw in a good ol' ABX test so the entire thread will be deleted. If you didn't know, AA doesn't allow ABX results, which is possibly the stupidest rule I've ever heard... promotes idiot-phile and voodoo audio. Just my 2 cents for the night.
bknauss said:Let's transport this thread over to audio asylum and throw in a good ol' ABX test so the entire thread will be deleted. If you didn't know, AA doesn't allow ABX results, which is possibly the stupidest rule I've ever heard... promotes idiot-phile and voodoo audio. Just my 2 cents for the night.
That's probably where the asylum part of it comes from.
Silver when hi-temp needed
My only experience with silvewr solder was decades ago when my dad build a custom rifle for moose and caribo. Silver was uses to fit the fron sight. The reason was that that ordinary solder would soften during repeated firing during target practice.
I suspect the same thing applies in other situations - silver has an advantage if the joint will be subject to temperatures high enough to soften ordinary solder. At the same time, you need to be careful not to damage a component by using the heat required rto solder silver.
By the way, if you have diodes that get unusually hot you may want to think of a way to heatsink them. I think an example can be found in the Leach amp website.
All this is well and good until you realize that silver solder as used in electronics is not the same as craftsman/fitter silver solder, which indeed has a higher melting point and is much stronger.
Standard LMP silver solder, 60 tin 38 lead 2 silver, has a melting point of just 172C!!
But I use it all the time; very easy to apply, nice bright finish to the soldered joint.
Hugh
Hugh
SS:
>I have used lead/tin solder on a few diodes that got so hot that they desoldered themselves. Silver/tin solder would probably have helped in that case.<
63-37 melts at 183C, while most lead-free silver solders that I have tried melt around 220C. On the other hand, semiconductor junctions fail at about 150C. So while silver solder may have yielded stronger solder joints, in either case the diodes would probably have failed.
>Silver and lead have different resistances and capacitances.<
Resistances, yes. Capacitances? I certainly hope not!
>but nothing drastic enough to change the way audio sounds.<
On one occasion I built a number of audio amplifiers that were completely identical except for the solder. The units were sealed up, marked with arbitrary identifiers and auditioned blind, per the procedure outlined here:
http://www.diyaudio.com/forums/showthread.php?postid=60831#post60831
In general, sonic differences between various components and configurations aren't always significant enough to get a clear-cut preference from my listening panel, but in this particular case, one of the silver solders was rated by everyone participating as being the worst-sounding.
I did not investigate the reasons any farther, but simply chose not to use this solder in production.
regards, jonathan carr
Post #3 Let's transport this thread over to audio asylum and throw in a good ol' ABX test so the entire thread will be deleted. If you didn't know, AA doesn't allow ABX results, which is possibly the stupidest rule I've ever heard... promotes idiot-phile and voodoo audio. Just my 2 cents for the night.
What is AA and ABX?
And yes, nothing blows voodoo talk out of the water like a good set of benchmarks.
Yeah, silver solder and silver-bearing solder are two diffierent animals... Silver solder comes in a few temps, hard, medium and low IIRC, hard melting around 1450°F.
IIRC, last time I tried silver-bearing solder, I got a crappy looking joint. I love led, helth prrblms b dmnd!@!!!
Tim
Tim
Everyone is uptight about lead now, well as long as you're not in the habit of eating solder, there's no reason to worry. Sorry if I'm not preoccupied with the concern for birth defects seeing as I am already born I read something somewhere about a possible lead tax but I think it will suffer the same fate as the soda pop and candy bar taxes did. Maybe the US government can destroy all the lead on earth so we don't have to worry about health problems, however, I believe dihydrogen monoxide is a greater danger.
http://houpd.home.texas.net/dihydrogenmonoxide.htm
All the motives for using silver bearing solder include either physical strength, higher melting point or environmental/safety issues. Supposedly, all Japanese manufacturers are switching to lead free solder, so if you think silver makes amps sound bad, you're out of luck because that's all you're going to see (or hear) in commercial amps in the near future.
***In accordance with forum policy, I must warn all of you that eating, drinking, touching lead and snorting solder smoke may cause birth defects, reproductive problems and just plain retardedness. If you believe silver joints sound better, you may have ingested substantial amounts of lead already. Do not use lead solder to cure headaches, spice up bland foods, or to floss your teeth, it's just bad mmmkay?***
Not recommended for diy dental filling repairs either.Solid Snake said:Do not use lead solder to cure headaches, spice up bland foods, or to floss your teeth, it's just bad mmmkay?
I saw on the news once someone actually fell into a large container of that stuff. It was fatal unfortunately.sikkek said:dihydrogenmonoxide
Yes I know. I once was submerged in the stuff for about 1 minute. Makes breathing impossible.... Luckily a friend pulled me out, after which I could breath again. Nasty stuff indeed...
Not So Nice Colours And Pigments.
Yes as I understand it, that is a worldwide directive to reduce lead leaching into groundwater supplies from landfills comtaining equipment containing lead based solder.
The soloution is intended to be tin/silver solder, and in my experience this sounds quite fine, and it is lead/tin/silver solder that sounds bad.
Eric.
"so if you think silver makes amps sound bad, you're out of luck because that's all you're going to see (or hear) in commercial amps in the near future."
Watch out too for common and simple mistakes like drinking out of lead glass decanters, and using coffee cups etc using glazes or plastics containing toxic elements like lead and cadmium."Do not use lead solder to cure headaches, spice up bland foods, or to floss your teeth, it's just bad mmmkay?***"
Eric.
Actually, lead crystal is perfectly okay. It's safely tied up as lead silicate.
BTW the real link is http://www.dhmo.org
Tim
Tim
Lead On The Rocks.
In the situation of whisky decanters, lead leaches out of the glass, and whisky drinkers using lead glass decanters were shown to have significantly higher lead blood levels.
Eric.
Not so according to a New Scientist article years ago."Actually, lead crystal is perfectly okay. It's safely tied up as lead silicate."
Eric.
- Member Areas
- The Lounge
- Lead vs. Silver solder
