Leach SuperAmp Photos
The wire is thin for 800W. However, during normal usage, you will only be sourcing a few amps. There are fans inside which continuously run. During normal listening conditions there is only a few degrees C temperature rise. When testing a full power with continuous sine waves, the amplifier was extremely hot. I don't recommend performing this kind of testing for extended periods of time unless your cooling system is rated for continuous sustained powers. I had a friend take these pictures while he had a digital camera. I will see if I can get some new ones on the site. Look for new ones near the end of April when I release the aforementioned Integrated Class-T Amplifier with ZVS power supply and off-line Power Factor Preregulator. I have mentioned it many times before and won't go into it again here. I will present the step-by-step process of designing and building switching power supplies (including magnetics) and Class-T amplifiers. Hope everyone is still intersted......stay tuned!!
BeanZ
The wire gauge from the Caps are 16AWG. The smaller wires that you see near the right side of the transformer are for the Stereo Blue LED VU meter. 16AWG shoud suffice for typical applications but there is certainly no harm in using larger gauge wire. And to peranders: Months ago I indicated that I would get you the board file, and it turns out that all I could dig up was an older file with just the two amplifier channels on a single board about 8" x 6". I can send them to you near the end of April. Why the end of April for all these things? I just recently moved to another city and I no longer have a computer but will again at the end of April...
BeanZ
BeanZ said:
I don't remember because it was so long ago. I would upgrade to the latest version (which now included a linked schematic capture program) and try to open it. Let me know if there are still some problems.
BeanZ
Hello BeanZ.
I have checked your PCB layout and it is a Protel file.
There are no aditional circuits, only the SuperLeach board.
Anyway, thanks for the layout.
mario
Super Leach Amp
Hi, I've been reading the posts and there is been taking about a pcb, schematic and super leach amplifier.
Can some one help me out? Can I see a schematic of the amp?
An URL is OK; the lore the better.
Hi Folks!
Dear BeanZ!
The pictures of the Super-Leach-Amp show a very nice built-up. I also planned to built up this big amp, but finally I decided to built up the "normal" Leach-amp vers. 4.5. This amp reproduces music very clear and clean with a deep dry bass. Therfore I can imagine how your amp "sounds".
Did you have any problems with the construction?
:smash: Wopo
Hi yeshu26
You are still looking for the pcb ? I thought you have got them already. I just get someone to make me an adaptor for fixing the the 8 TO-3 (on a seperate board) to the heatsink. I don't know how long it's going to take him but I can go on with the pcbs. I had modified Mr Leach's original pcbs to a main board and made an output board to accomodte the 8 TO-3 along with some components. There is still some wires connecting the main and the output but they can be done using much more thinner wires. Attach is the output board.
Hi ,my amp integrated on a computer
It's my amp
Hi PROSTAKA
That's another nice piece of work especially for computerist. Any interference from other parts of the computer at all? You have another source of interference, the TV capture card. Really like to know if your leach is doing as good as it does when "out of the box". I like those connectors and the wiring. That's also what I am using.
Hope this dosen't offend you : everything looking so elegant and tidy except the 2 white 'power lines'. I bet that they were not even plated core lines. Why don't you use the computer power cords? It might be a bit wasteful to cut out the plugs at both end of the cord, using just the middle wire portion. But I think that perfects the whole picture. I had those kind of wires also and the only place I use them is going from the wall socket to a power bank or some domestic appliance which need a really long wire. They can get worn out even at screwed terminal inside the power plug and it always cause a mal-connection.
