"Le bouledogue" (The bulldog) a very fun project with the SLS P830945 and SB26STCN
This resonnance peak is the dome resonnance of the driver near 4kHz. For a 5" it usually higher. This driver is usable till 3kHz. If you look the directivity till 2.5kHz.
There are too much marketing in the loudspeaker market with products line, range to sell more ? and we should never trust manufacturer data. The 830945 is a rare example of better than specified. The specs recommended 50-1000Hz, I use it in the range 40-3000Hz.
Reactions: 1 user
