dnsey said:I'd gladly hire one for a few hours:
I've just obtained some unique direct-cut recordings by famous 'swing era' musicians. These comprise a ?celluloid film carrying the groove laminated to a glass carrier disc. Some are becoming delaminated, and could not be played conventionally without serious risk of destruction.
I suspect that a laser turntable would find serious application in conservation work like this.
Those celluloid film laminated to a glass are "acetates", and one can only hope that Laser Turntable is the only solution for them.
Unfortunately not - it can play only black coloured flat records, for all other material, it will produce large skips.
I think you can visually scan the surface of any physical medium to a computer, and converting the image to wave forms is not terribly difficult.dnsey said:I'd gladly hire one for a few hours:
No need to track the surface in real time.
