yes it is a Jupiter FLAT stacks , but KASUMI what is this big 10000uf output caps? 🙂
they came free with the Jupiter Flat Stacks 😀
Finished Motorcycle Maintenance. Re-reading Watership Down now. 🙂
This is my current favorite OT post in all of the interwebs. 😀
Those are both great books.
for that it really needs some rearranging
Finished Motorcycle Maintenance. Restarting Watership Down now.
FOR FREE !!!GIVE ME TWO 😀
Has anyone purchased from this guy for their SIT?
4pcs CDE 75V 37000uF Computer Grade Bus Capacitors New | eBay
Dan 🙂
Dan 🙂
Yes, and those appear to be the same caps I used for the article. I've purchased numerous caps from them over the years.
Hi all. This is my first post since I'm in diyaudio.
Juanitox, Have you used the grid choke in the gate pin of 2sk82?.
then, have you reduced the input capacitor?.
and last, are you still using the 193V inductor and supply of 24VDC?
Thank you.
Thank you.
hi michael , yes i have tried my grid choke in 1:2 step up but don't really like the sound (loosing some definition in a SET tube amp input ) , i use it just as a gate load for the SITas i have to much gain on my system. it works very well as i can use a fancy smalerl input cap with the high AC impedance of the choke. i still use the Hammond choke as i 'v got the best sound with them and my 8 ohm horn speaker.. i have tried different setting of bias ( 1,6 to 2,6 amp and 55W on the 2SK82!😀) and the 2amp 22V michael have found seems the best as usual🙂
I was looking at trying a CLC power supply and was shown this simulator
PSUD2
I dont really know what I was seeing,but a more intelligent forum colleague said there was some ringing in the simulated cct and said it might be worth looking into damping the ringing,anyone got any thoughts on this and PSU D as a simulator for the SIT amp
I'm a paint by numbers DIYer so any guidance appreciated.
Some more stuff hear
http://www.world-designs.co.uk/forum/showthread.php?t=1479
PSUD2
Yes, more info needed. Ringing in what? The simulated power supply?
You could just replace the CRC resistor with a 12-14 ga. 2-4mH air core coil if you want a CLC.
hi Kasumi , could you try my config in PSUD ( i don't know how to use correctly PSUD ) with 18V AC 22000uf ( 0,01 esr) 10mh ( 0,47 ohm) 37000uf (0,01 esr) .. and tell me if you see any ringing? thanks !
hi Kasumi , could you try my config in PSUD ( i don't have windows PC ) with my CLC 18V AC 22000uf ( 0,01 esr) 10mh ( 0,47 ohm) 37000uf (0,01 esr) .. and tell me if you see any ringing? thanks !
First time I used PSU D was yesterday 😱 ,so I doubt I know what I'm looking at or doing.😕
There is a very knowledgeable bloke on another forum I use that inferred that there was ringing in the sim I had using a 20mH inductor in a CLC config.
I started with that as that was what you said you used in a past post.
I'll just go with what Mike recommended 2-4mH and leave these sims to the pros 🙂
Those values worked nicely for me. I haven't tried any big iron myself, but I'm sure its good.
It's hard to say what your friend might be referring to, so I can't help there without seeing the simulation results.
You could observe the real ripple waveform with your scope if you have one.
Hey Rob, just to clarify, I think you might have misunderstood - I didn't say there was ringing in your sim (I didn't actually sim it yet), I just suggested using PSUD to simulate your cct. and one of the things to look out for is ringing when you add a current step (you can see the oscillation in the waveform. I was in a hurry ad missed the details in your PM. Knowing the DC resistance of your power transformer and proposed choke would be good, too as they will affect it.
Here's a sim using similar values to the ones you sent: 37000uF - 20mH - 37000uF, 2.5A load. (I substituted a Hammond 159ZE (28mH, 0.43 Ohms) choke as that's a real part.
Look like you get about 2V ripple! That seems quite high...
whoops,yep I'd thought you'd done a sim ISC and had seen some ringing and thought it may have been overlooked 😱
Good point, I'm more used to tubular stuff. What's a sensible value? 0.1R?
ok, 0.1R give more sensible results. No ringing when stepped, but looks a bit over-damped to me - I'd aim for a slightly faster rise.
- L'Amp: A simple SIT Amp
