KT88 bias current keeps drifting
Hey guys,
I need your help. I built a prototype power amplifier in the lab using KT88 tubes in push pull ultra-linear. I am having a hard time biasing the tubes since the the cathode current keeps drifting up or down. I have the HT voltage set to a regulated 500V so I am biasing at 50ma quiescent current. Sometimes I can get the bias currents matched but when I play some music and then check the bias currents again, they are different by more the 20ma sometimes.
The tubes are Electro Harmonix KT88's and they are new (and supposedly matched), so I am wondering if this the reason. However, sometimes the bias can drift from 50mA to 80mA which is getting very close to the anode's maximum power rating. I am using an AnTek 70W toroidal output transformer wired for ultra-linear (I will eventually upgrade these to Edcor). What I find puzzling is that when the cathode currents are balanced, one tube's grid is at -57V (which is expected from the data sheet) and the other is around -48V. The bias supply is stable and regulated. Since these tubes are "matched" they should not be that different. If they are not matched, would there still be that big of a difference? Could I have a bad tube?
I was powering the tube filaments using a switching DC power supply at 6.3V. The bias regulator schematic is attached as well as my amplifier schematic. The power amplifier design is by Bill Christie which I found in an AudioXpress magazine (Jan 08 issue) titled A Hybrid High Fidelity Amplifier. The design uses the LM4702 driver chip to provide enough voltage swing to drive the grids. I was not using any global feedback.
Any ideas what could be the reason? The amp sounds quite good but when the bias currents get too far off there is some crossover distortion which is expected.
Though I'm not familiar with the front end at first glance the resistors (R28, R29, R35, & R36) in the bias circuit look too large Ohms-wise. 100K or so for R28 and R35 is more the norm. Not sure if this will help but it's worth a try.
Craig
Absolutely. You need to have a path to ground from the grids. These tubes have large control grids which will accumulate unwanted electrons. They need a drain or the the tube will run away. GEC data sheets specify a maximum of 220k ohms for fixed bias applications where total dissipation is less than 35 watts.
I'm a rank amateur so my two cents may not even be worth that. But I'm with JAM. Why would anyone want to use a single bias pot even with so called "matched" tubes? Also, Why would you want to use separate regulators in the same circuit? Is this a current limitation thing for the transistors? If the DC voltage varies even a little bit wouldn't that throw the bias off? And if so would you need a DC balance pot? Also, how much does your mains voltage vary? And if you have a single bias pot shouldn't you have a single cathode resistor? As always I have more questions than anything else. Hope I haven't embarrassed myself.
There are two bias pots here. R48 sets the overall bias voltage, and R47 balances it between V3 and V4. It's a very usable arrangement.
R30 and R37 aren't really cathode resistors in the traditional autobias sense. Their value is much too small to be useful as bias setting cathode resistors. They are only here as current sense resistors.
That is the real problem. The KT88 demands a low resistance from the grid to the bias supply and the bias supply itself should be a low resistance. The data sheet shows a maximum total resistance for the entire bias path of 100K ohms in fixed bias operation. Your circuit has well over 500K. This can lead to bias drift and tube runaway, especially with new production tubes.
The bias circuit itself uses two pots one sets the bias level and the other sets the balance between the two tubes. This is a perfectly good circuit and is similar to other circuits I have used. The resistor values need to be scaled so that the total resistance is under 100K from each grid to ground.
I have a copy of a Genalex data sheet. It shows 220K for cathode bias and 100K for fixed bias. I use 130K in cathode bias since I have seen Chinese tubes go nuclear with 220K. Either way 470K is asking for a visit from the smoke monster!
Ok, I changed r29 and r36 to 100k and removed r28 and r35. Although a big improvement, there is still some drift in current. Should I reduce r29 and r36 even further? I thought my caps could be leaky so I removed c8 and c11 and the bias was still drifting. I might have to try a completely new bias circuit🙁
The neg bias circuit you show suffers from some drift but not the amount you describe. Amongst the bias resistor values being too high, You don't mention what type those
10R cathode resistors are. I had similiar quiescent runaway and discovered it was due to the 1W film o/p stage cathode resistors going high. I changed to wirewound 3W Dale types and problem solved. Any other ww types will suffice.
MAny modern oxide/film resistors cannot take transient impulses typically found in ouput stages and will go resistively soggy despite all power ratings being in order.
DO a test. Disconnect one from circuit, fix ohmmeter to it and apply the soldering iron and observe.
please reply
richy
Hey guys,
There is a known issue concerning certain batches of Electro-Harmonix KT88s having unstable bias and not being able to balance even matched pairs. They drift as the temperature changes. I won't speculate why, just to say that on a forum dedicated to a PP KT88 amp using a CCS on the cathodes it is recommended to stay away from the EH KT88 because it was the only tube out of every brand tried that would not stay balanced. Certainly the circuit can exacerbate the problem but if you change brands of tubes you might find your bias problems disappear.
I have EH KT88s in my amp with no issues. I didn't get my quad from a bad batch.
I am using 10 Ohm 5W wire wound resistors for the cathode current sensing. I might try changing these resistors to another type just to see if it helps and also do the soldering iron test you recommended.
I am going to reduced my grid to ground impedance further and check my power supply stability. If there are still drifting issues I might try a pair of 6L6's I have and see how they perform. If they are stable its probably a bad batch of EH KT88's.
Sounds like you've loaded the grid-grid impedance down hugely (<50k)??
What should the impedance be between grids?
Thanks TY for pointing out there are two bias pots. I'm currently finishing a pair of Mark II clones and using Joe Curcio's front end. But I used two separate bias pots rather than this arrangement. What is the advantage, if any, of one overall pot and a balance pot between them? Seems like separate circuits is a better idea?
