Well i think i'll start gathering parts. This will be my first high power tube amp, (above 10 watts
) It seems that lundhall transformers are highly regarded here, i've never used them
. So, what else do you recomend for this project? I have a couple of power transformer that should work, it came out of some homebrew ham equipment, its quit large, 375-0-375 no load with 2- 6 volt sec. and a 5 volt sec. core is a hair cmaller than the first one i listed in the first post, i'm sure both are good, should supply plenty of current. Any one ever use a Ma meter in a project to keep an eye on things? I'll build it to the original first and then make changes, this will probly be a long project. Thanks for all the help
Jeremy
Jeremy
