I also trying to get transformers for 2 amps
which transformer you chose - original Avel or Toroid In previous post
also what are the spec for that transformer
how transformers like this I need for one amp 1 pcs or 2 pcs
how Is going to be done shipment of the trans
they will be shipped from the factory to floedstrome or Individually from UK to every receipt
how much will cost shipment from UK to Sweden
You need 2pcs for a stereo amp.
About shipping:
We can proably do what we want.
But I guess it will be most easy to send to one forum member, and then directly to all others from him.
Also if there are lots of orders from one country, we ship all trafos to one forum member and then he sends to each member in that country.
I can be the contact person in Sweden, I have a VAT Registered company, and can handle shipping and everything.
About shipping:
shipping question
If this happens... I have a friend within the UK to whom I 'd like mine shipped. Is that problematic? Seems to be extra cost to go from the UK to Sweden & back.
Thanks.
Ryan
Thanks.
Ryan
there are two things
price of the transformer - 155 pounds - very high for 1 pcs also there are VAT (how much ) shipping
quality - for that price range the transformer have to be like Plitron or even better
what do you think of the option - other manufactures - Plitron, Hammond, Toroid (stolvoboy USA GB)
Guess shipping will be the easy part...
In Sweden/Denmark/Norway VAT is 25%
But if you have a VAT registered company you can remove VAT.
In Bulgaria where I am VAT Is 20%
How about quotation from www.amplimo.com
they make HQ they are closer their prices would be better
imho, if you are fixated on spending so much money you would be much better off requesting a quote for an R-core transformer in an R-600 to R-1000 size. (eg Arrow in HK)
Even ordering a few dozen 500VA R-cores at Selectronic in France and picking them up in person at the Belgian/France border line store in Lille would be cheaper and a whole lot better.
(but what do i care, i w&d 2 NOS big gun Plitrons for the KSA out of Germany, for 50 buckeroos each)
Maybe Jaccos alternative is better ?
Since I don't know what we need for specs, and Floedstrom checked it up maybe Floedstrom can get quotes here.
If we can get a Lower price with same quality and specs then is ok.
I asked www.amplimo.nl for price of 2 pcs x-formers
to me amplimo and plitron are of same quality
primary - 230 VAC
secondary - 35 VAC x 2 8.95 A
- 55 VAC x 2 0.75 A
- 15 VAC x 2 1 A
this spec will do work for me
here are what they offer me
We do manufacture custom-made designs, however a production batch of only 2 pcs is not very economical and therefore expensive.
We can offer you this transformer in “audio-grade / low-noise” quality for EUR 200,00 nett, excl VAT each.
Dimensions : diameter approx 160mm, height approx 62mm.
Delivery: EXW (incoterms 2000)
Payment: in advance.
I suggest Floedstrome to ask for a quote,contact them and tell what spec are better to use for that amplifier
I will buy 2 - 4 or even 6 depending on price
primary - 230 VAC
- 55 VAC x 2 0.75 A
- 15 VAC x 2 1 A
The "original" trafo that floedstrom have prices for
1-4 units: £ 200 ($ 400)
5-29 units: £ 155 ($ 310)
Guess they are pretty the same, and then I prefer the "original" ?
200 euro for 2 pcs Is better than 200 pounds for 4 pcs
transport will be less expensive from NL than GB
I have heard there are some avels make noise
for KSA100 Klone the 35Vac is slightly low.samoloko said:primary - 230 VAC
- 55 VAC x 2 0.75 A
- 15 VAC x 2 1 A
The 626VA of the main windings is very low.
36Vac or 37Vac and 12A would be closer.
don't you think that for bias 2.65 A it is enough to have 625 VA per channel
sure It Is not original but what Is the reason to have much more
a transformer feeding a capacitor input filter must be rated to deliver a continuous DC current of pretty near half the rated AC current.
If you want/need a continuous rating of 2.65Adc then the minimum rating for the secondary is 5.3Aac.
But this will run the transformer at it's maximum rating continuously. It will run HOT.
It is usually recommended that the continuous load be less than about half the maximum rating to stay within tolerable temperatures.
This requires an AC rating of >=10.6Aac.
I think Krell specified their transformer on regulation not maximum temperature. Their toroid would run even cooler due to the extra copper and iron to get their regulation specification.
thx andrew
what do you think about 55 VAC 0.75 A Is it good to be used with Bob Ellis scalable regulator 45 - 65 VDC
Samloko:
We only need 5pcs to get £155 price, and that's similar to the one you got in price. Alse we have the original manufactor, and similar specs as possible with all volts needed and lots of ampere 🙂
- Group Buys
- KrellClone KSA100-MKII 1000VA toroidal transformer EUROPE GB
