Hogwash !
Sustained bias plateau shoes, but still a midget.
Mmm,
those metal bars connecting the output with the terminals is nice.
And the stacked boards, with the big capacitors screwed straight to the rails, too.
Oh no, the fool is starting about silverplating copper bars and screws again !!
Does anyone know how many output devcies the S had ?
I've seen this picture some 10 years ago and even then it wasnt sharp enough to count the number of TO3 pins.
With the kind of heatsink on the S i would think 6 would have been the most logical choice.
Going above 35vdc rails will be a problem for the opamp in the Jung super regulator. Checked for possible solutions by doing a search ?
Mmm,
Mr. Lantern,
I blew up the pic and enhanced brightness, clearly I see 3 connexions on the heatsinks, i.e. 6 per channel as you suggested.
The soundstage was wicked big; the bass was wicked deep; the amp was wicked GOOD!
The KSA-50 Clone... now at WWW.DIY.COM
That about sums it up. I say we order a big batch of T-Shirts with that quote on them. This thread is also wicked good!
Mark
Are there any boards/parts groups left? I'm kind of in the market... (blew up a musical fidelity synthesis). Any price quotes? If you need to recoup some losses with higher cost, it's fine. Thanks.
I found it!
www.hear.nl
Go to the forum, then choose "algemene onderwerpen" and then go to "dit is nou een topic waar ik uren naar kan kijken".
Lots more very intresting pictures here.
Have fun.
www.hear.nl
Have fun.
philibuster said:Hi,
Email me if no one else gets back to you.
Yes I have 6 boards left and I brought them with me on the road.... You can e-mail me at cinerama84106@(remove)yahoo.com. For details.
I have ordered another 100 boards but I took the slow route of 1 month delivery time..... I am also getting them made on .062" fr-4 instead of the .093" stuff. This might help the hole situation a tad bit.
Mark
BrianGT PowerSupply Boards
I know it's been asked, but I'm not sure it's been answered...
For those that are using the BrianGT PSU boards, where are you sourcing your caps? The boards take SNAP-IN type caps, 3 per channel. My math puts that at 27,000uf a cap, and would need to be 50V. Anyone?
~Brad
~Brad
Re: BrianGT PowerSupply Boards
I'm using these (left side, 10K @ 63v) in my BrianGT boards, but these are not going in my Krells.
http://www.apexjr.com/new.htm
googler said:I know it's been asked, but I'm not sure it's been answered...
~Brad
Boards Received
Hi
I have just received my PSU and Krell clone boards. Nicely packed and undamaged. Many thanks!
Reading the Salt Lake Tribune newspaper they were wrapped in was a eye opener. Jeeps going for $18,987 ! (Dollarprice X Rand conversion rate of X6,3= R119618.10) when the local agents are selling them for nothing under R300.000.00 ! The same applies to audio- what most overseas audiophiles consider cheap stuff works out quite expensive here.
With a second KSA clone in the pipeline I am keen to make this one a no-holds barred version. Any recommendations re best components to use will be welcomed.
Jozua
Cape Town
South Africa
Hi
Jozua
Cape Town
South Africa
Any body looking for a cheap supply of high grade capacitors should check out this link.
http://hk.geocities.com/wkchenghk2000/orderformEng.htm
ANDYLASER said:Any body looking for a cheap supply of high grade capacitors should check out this link.
It says "Eng" in the URL so I would assume it was the english version, but I keep getting... ^#%_(*^%!^$@($)_(
- Krell KSA 50 PCB
