Krell KSA 50 PCB
Pinkmouse, at the moment I am looking at the aleph30, and have boards mostly populated, just in need of output devices etc.
in the planning stages are ksa 50 and poss 100 (probably some time away).
so i am probably looking for 1 straight away and another 2 in some months time. how much do you want for that blue one?
I'm having a big problem with one of my monoblocks, and was hoping that someone might have an idea on how to correct it. Basically, I have built two monoblocks, and one works perfectly fine, but the other gets extremely hot.
The reason for that is that when I measure the voltage across all 6 emitter resistors, I get 3.6V. I tried turning the bias down through R126, but nothing changes, even if R126 is at its max resistance. I rechecked all the transistors and compared the faulty monoblock to the working one, and I couldn't find any difference in terms of components. If music is fed to the faulty one, it seems to amplify it well, but due to the weird biasing, everything gets very hot very fast, and both rails drop about 10V from what they should normally be, which I guess is normal with 3.6V instead of 0.4V.
Does anyone have any idea what can cause this?
Thanks.
Paul
stick a high wattage (150W or even 300W halogen) bulb in series with the amp mains input.
It will pull the transformer voltage down very significantly and may give you just enough voltage to measure things.
The front end LTP stage voltages will go a bit haywire but hopefully at the output end you can ignore them. I have not analysed what happens to the DC set points at very low supply voltages!
I keep referring to this bulb thing because it is virtually foolproof for first start up.
The PS is composed of a transformer with 28V dual secondary, each secondary goes to a bridge, then there are 4 10000uF capacitors on each rail, and each 10000uF cap is bypassed with a 0.033uF polypropylene cap.
On the faulty monoblock, the rails are very low, but on the working monoblock, the rails are at about 36V.
Paul
Thanks for your help guys, it now works normally. All along, I was looking in all the wrong places for the bug, and never thought about Q111; Pinkmouse was right on. Now that I look back on the voltages I posted earlier, it makes sense that Q111 should be at fault.
At least I've learned something from this 🙂
Thanks for pointing me in the right direction guys.
Paul
