Krell KSA 50 PCB
check the construction wiki for this project...
I'll go read it again, I'll add what I know that isn't already there, it would be cool if everyone else could do the same...
Mark, those amps look beautiful, I hope I can get the larger one to look one tenth as clean...
Stuart
Actually the best place for this is on the KSA-50 web site. I will begin to gather together al the stuff and get it posted there this weekend. I may need some help getting photos and diagrams posted but hopefully Brian GT will help with that. If he's busy( and I'm sure that he is) I may need another html literate person- volunteer to help out with getting the site situated I think Brian already has at least several cups of coffee going so are there any volunteers out there just in case?
Again, I will be out of town installing new projectors in a cinema up in Idaho the rest of the week but I will have my laptop with but infortunately just via modem at what ever motel I end up at.... I will however peek in while on the road and see whats going on.
Mark
building guide wiki...
...is at:
http://www.diyaudio.com/wiki/index.php?page=Building+guide
I have added 'normal' voltages for test purposes, plus transformer and cap info...
If finding the exact value of the resistors is difficult (I wouldn't really know I didn't try) using the standard 5% values nearest to the one specified works perfectly. You can get every value you need at radio shack if you are in a hurry...or at least I did...
Later on, for the next couple of channels, I went to the local electronics store and got some nice 1% metal film...
Stuart
Mr Green,
i took a look at the pictures of your heat duct setup.
I counted 77 holes, if they have a 1/3" diameter airflow speed will be in the range of 27 ft/sec, with a 70 cbft/min fan.
Even if you derate the fan to 50% airflow speed through the holes will be too high.
Which will lead to turbulent flow because of the edges of all those holes, and have a serious effect on your fan efficiency,imo.
Better than adding many more holes would be to increase the diameter of the holes.
If you can i would clean the holes with a smoothing bit after you've drilled them, even better would be to smooth the edges.
(a 120mm fan has a cross section of 18 square inches, 77 holes of 1/3" diameter only add up to 6, >> 1/3d)
Mark A. Gulbrandsen said:
The proto type amp is all up and running just fine on the bench supply so Al you can sleep now...
Yeay!
I'm glad you approve of the neatness, it's one of the things I was trying to achieve, despite the separate board strategy. One thing you might want to try to cut down distortion, is to run each board with it's own feed from the PSU caps, and of course the option is there to use Pavel's decoupling caps.
Gengis, I'll get back with the cap sizes later, or you can just print out a copy of the board layout and measure them if you're in a hurry.
I've got a question about the way Mr Green is using his fan as well. Wouldn't it be better to mount the fan at the bottom and blow into the tunnel rather than at the top where it is drawing hot air? Seems the life span of the fan may be seriously reduced by the heat.
Thanks, Terry
I would have thought that if the air the fan is sucking is hot enough to damage it, then the amp is probably already in meltdown...
BTW, in general, you want to blow air onto a heatsink, as this disrupts the laminar flow and cools the surface more effectively.
Fans have better efficiency when blowing than sucking.
Sucking they create underpressure in the duct, when blowing an overpressure.
Higher pressure means higher massflow.
Al covered the turbulence bit>> with laminar flow there is a layer of air over the heatsink that reduces friction and isolates thermally.
I think Mr Green will be sorry he chose a 70cbft/min fan
Input Board
OK OK OK OK Enough about the fan and the vent holes! I appreciate the comments but, and you can quote me on this-
I will be the happiest man on earth if the biggest problem I faced was heat on the output stage. Must get circuit working!!! Heat can be easily fixed. Last time I show you guys anything of my work in progress
Soo, how about those driver boards?
Here are mine:
oops. didn't meant to show these so soon...You all will probably make fun of my huge zener diodes.....and tiny heat sinks....
All assembled except C105 and C106...I recall a discussion about 1,000 posts ago regarding the proper values for these...they are listed as 390 pF but I think people were using 100pF??? Have I got that right?
For those of you getting parts, look at the handwriting on the parts list. You see that the resistors you can order (I used Mouser - dale CCF I think) don't match the parts in the schematic, so I wrote in the next closest that I could find in a 1% tolerance. I hope these work but if you see anything wrong, let me know.
Now, about C106 and C105???
Re: Input Board
Aren't the pictures of the boards "anything of my work in progress"
Why don't you reduce the size of the pictures a bit so they fit on the screen?
Blessings, Terry
