I like the added drivers to handle the extra output devices.
You must have a tough load needing some attention ��
David
David
I think IT is a mono Amp.
Good catch. Big monoblocks. Impressive.
hi.
i really like the sound of my krell's. very powerfull and really smooth class a sound.
i use 16 transistors per channel. no changes needed. just lower biasing.
the inductors are for CLC filtering in the power supply.
regards
regards
I only see 4 pairs/channel.
yes those are monoblocks...
Hi Fencki,
Which PCB did you use i could see some writing but is there a link to this one ?
- it is good to see people making high quality diy amplifiers still, with the amount of rubbish which is around now !
-Dan
Hi Fencki,
-Dan
thank you...
i got them here in this forum from a user. he cloned the original boards... think it was username pwatts...
thank you...
Thanks Fencki
-Dan
I have just started a new project.....
KSA100 MKII clone, so far I have nearly all on board parts including the output stage.
I am at the point of deciding on what type of case to use.
I will be using passive cooling but not sure which one yet.....
hello! here is my clone of ksa50! Sound great as original.
Great work!
thank you very much!Wow, that looks elegant and beautiful!
this clone made in china. aviable on aliexpress for 1350 usd.
No, especially selected and "rebranded" 15024 and 15025.
R
Could just match some MJ15024 / 5 🙂
- Krell KSA 100mkII Clone
