hi. this is mostly for bobgroger. I would like to buy 4 pcb's for the krell 50II is that still possible?? sorry, I cant write to you personally because im a new member on this board. hope it is ok to write in this thread.😉
Hi Schubert_dk,
mail me bobgroger_at_hotmail_dot_com
Lots of KSA50 boards left, KSA100 boards are gone. In fact I still have a GB member I need 2 boards for, if anyone has changed their mind about this project.
I guess at this point we should do a check for interest in another board GB? Should we move this to group buys or keep it here?
Bob G.
Bob G.
Why so quiet
Harry
My intention was to build a No Hold Barred Ksa100 with a professional look to it. When I handed my expensive heatsinks to a metalshop to start with the case and the workmanship I got back was worse than a backstreet DIY job. That was a major dissapointment to me.
I then bought a broken KSA150 with the intention of replacing the innards with the KSA100 but it now working and sounding very good- possibly better (more detail and very fast) than my KSA100.2.
I then found new heatsinks for the KSA clone but they still have to be predrilled. This time I do it myself.
Rest assured I have not lost interest - it just that my strategy has taken a few unexpected turns and expenses.
Jozua
Harry
Jozua
Good to hear from you Jozua and I am glad you are still working on the KSA100.
Mine seems to be taking forever to put together and I still haven't worked out how to place the 8 output pairs on the heat sink. I might need to design a PCB as I hate wiring.
Best regards to you and Pierre.
Andrew what's your progress?
Hi,Harry3 said:Andrew what's your progress?
I put mine aside until more feedback comes through on other builds.
I'm beginning to wonder if my oscilloscope/signal generator were misleading me. But unfortunately after replacing both I still ended up with blowing fuses or ringing when adding caps in parallel to 8r0 loading.
Anyone interested in a Groupbuy on the original/similar heatsinks with a fan from Fischer Elektronik GmbH & Co. KG ?
I got a quote on €100 / each
* Heatsink for 8 TO3 (2 on each heatsink)
* Papst Fan @ 230v (guess they have 110v too..)
* Predrilled for the TO3's
(Complete)
I also have a quote on just the heatsink (1000mm) for about €50/each
Then you have to cut it and drill it and get your own fan..
http://www.fischerelektronik.de
Waiting for an answers for 10,25 and 50pcs
** Pictues is not showing the actual, just so you all can get an idea... **
(Complete)
AndrewT said:Hi,
Minor problems 😉
I'm sure you will find the problem. If not, soon there will be a few amps up and going and we will compare. Not forgetting the resident gurus like Pierre and Jacco.
Heatsinks (& Transformers)
Hi Fix,
I may be interested in your GB of the heatsinks (I have my own fans) if the carriage costs to the UK are reasonable. I would be looking for 5 units.
I continue to look for reasonable cost transformers so I can start this project but so far either the transformers and/or carriage costs break my budget whenever a find a candidate.....
Is anyone else in the UK/Europe suffering the same fate?
Hi Fix,
I bought two transformers on Ebay.
each were 1kVA 74+74Vac.
I split each winding to give 37+37+37+37Vac and used parallel sets of windings to double the current capacity.
I could add extra windings to bring the voltage up slightly but decided after power and temperature testing that my DC voltage was high enough (453W into 2r0).
If you look long enough you can find bargains that are capable of good results even though they may need a bit of work.
using those 37Vac secondaries.Mains 241Vac
Bias set to about 2.6A, Psupply =+-50.1Vdc
maximum outputs
into 8r0 33.1Vac OCv 33.3Vac =137W =+21.37dbV
into 4r0 32.1Vac OCv 32.6Vac =257W =+21.10dbV
into 2r0 30.1Vac OCv 31.1Vac =453W =+20.54dbV
I've got quotes from toroid.com.
Quantity- Price ($) each
5- $302.32
10- $260.97
I plan to make an order next Friday, March 21st.
Please contact me if interested.
http://www.diyaudio.com/forums/showthread.php?s=&postid=1460757#post1460757
5- $302.32
10- $260.97
Sorry - March 28thstolbovoy said:I've got quotes from toroid.com.
To: Barryblue
Great!!
I need 2 myself...
Hopefully I get a quote tomorrow, guess shipping is quite cheap in Europe.
Soon as I get a final quote and specified details I post it here.
Great!!
I need 2 myself...
Transformers
Andrew
Thank you for the info on the txfrs.
Can I ask how much you paid for them on Ebay including carriage?
Andrew
Re: Transformers
I also bought from Rapid when they were discounting their NON ROHS transformers. Again some great deals on wire and resistors as well as transformers.
I now have about 30 suitable transformers for any projects that I care to take forward.
I bought them as a batch of 6, about £20 each. The others were a bit smaller. But I have been patient waiting for the right deals to come along.barryblue said:Andrew
Transformers
Hi Andrew,
Thanks for the info.
Yes I bought from Rapid too.
I just need to find the TXFRs for the Krell Clone at the kind of prices you have achieved.....
Hi Andrew,
@Barryblue & AndrewT
Since you also live in Europe, I wonder if you need a Trafo for the project ?
If yes maybe we can start ower own GB for the Avel Lundberg trafo together with Floedstrom ?
Let me know, else I will proably jump on the train on the other GB
ask Avel if they will deliver in two batches.
One to US and the other to Europe.
Then local distribution to keep costs down.
Stolbovoy is ordering from USA, and not from Avel Lundberg.
Guess we can order from him, and take one batch inte europe and then split it.
Else we do a own GB..
Don't know if Floodstroem got a price qoute last time he checked?
/Patrik
/Patrik
Hi Fix,
a 900VA 38Vac transformer has an AC current rating of about 11.8A continuous.
If you use it to feed a capacitor input filter the maximum contiuous current rating falls to about 5.9Adc.
At this current the transformer will run hot and this may be the temperature rating that the manufacturer has found is critical for their design of transformer.
For a Class A amplifier drawing 2.6A of bias plus some other small current loads, the transformer will be running at about 46% of maximum rating. This is about the usual maximum for a transformer, leaving the remainder for short term peaks. (It's why Pass recommends transformer VA~=6 to 7times amp power rating)
Uprating to 1kVA and running two ClassA amplifiers from it will draw about 82% of maximum rating continuously.
The transformer will run HOT. Worse, the amplifier internal ambient temperature will be high due to the ClassA dissipation.
You have nothing going for your idea of running a single transformer KSA two channel amp except saving money and risking unreliability.
You might get away with 1.5kVA, but the allegedly low regulation of the Krell spec transformer indicates it had a large area core and a high copper content. Both these will result in a lower operating temperature for a genuine Krell transformer. It may be that building their Transformer this way resulted in their 900VA spec and that this may be more equivalent to other manufacturers rating of nearer 1.5kVA.
That may be the reason that Flod's Krell copy was so expensive.
- Krell KSA 100mkII Clone
