Well with the O/S not on the PCB itself leaving it out is simple enough. Maybe on a next version there can be a more elegant way of doing it though.
About the DC-coupling of the feedback loop for purists preferring not to have capacitors in the signal path, there is provision for a jumper on the PCB, so briefly shorting it out is a breeze.
I've SPICE'd the circuit; in fact I've SPICE'd the KSA50, KSA100 Mk1 and some of its variants too to investigate the influence of different components and check how they compare to the math. I'm very busy lately but will try to experiment with DC servo's when I have the chance.
Mark A. Gulbrandsen said:What difference did you hear?
I wasn't actually doing critical listening, just had some background music playing whilst checking heatsink temps, but I didn't notice a difference between the channel with feedback connected and the disconected one.
Mark,
add another succesfull paypal transfer to the list.
Pierre,
the additional features of the boards are highly appreciated, could be the first GB boards i'm not mutulating.
Pierre,
Payment
Hi Mark,
Payment sent for 5 boards.
Thank you and everyone who has made this project happen.
Cheers
Hi Mark,
Cheers
paypal
Hi Mark, i mailed dr.Strangelove3 to arrange the payment for his pcbs, so we can save on shippng.
Jacco was, as usual, very fast and paid allready; but maybe it is not to late to share the Dutch shipping parcel?
Greetings, Loek
Greetings, Loek
Hi Mark, payment sent for 4 boards, and thanks for all the work in making this possible.
If possible, could I please get 2 with the solder mask and 2 without?
Stephen
Stephen
fast
Sorry dude,
i had this picture in my skull of Mark sitting on a pile of boards while he was eating a bunch of checks.
The swift response is like a seditive.
Me too!
Mark,
Thank you so much for organizing yet another group buy. I have just sent you the payment for my 4 boards.
Mark,
heatsink
I might be able to keep a channel or two comfy with this ... no?http://cgi.ebay.com/ws/eBayISAPI.dl...MEWA:IT&viewitem=&item=290050516535&rd=1&rd=1
HI
Would you please somebody let me know were I can find the BOM for the KSA-100 .Right now all the resistors are on sale at Partsconnexion . Only 15% of but better than nothing .
I would like to colect the pars until the PC board will be ready ..
I don't know whether this is the latest edition, but it's the one I used.
EDIT: Removed the BOM because it was not the most updated version.
Don't want anybody start ordering wrong or incomplete parts.
That BOM is a bit outdated and has a few errors on it as well. The FET's are listed incomplete and since I changed the PSU configuration the decoupling caps have increased and assigned different reference designators. The jumpers have also increased from 1 to 3. The updated version is at work unfortunately but I'll post it tomorrow.
The resistors and caps of the non-optional section is correct though, but I'd change R17 & R18 to 0.5W too to be on the safe side, and R38-R41 cannot do harm by going to 0.5W as well. The only one that's mandatory to be 0.5W are the 12k's since they dissipate over 120mW.
Since I've to place an order at Parts Connexion anyway, I'll see if I can add the order numbers and prices to the BOM of what would be a good balance. It will be a combination of PRP, Holco and Mills resistors, polystyrene and silver mica pF caps, BG Std for the 10uF 16V (they're cheap anyway) and Solen 1uF for the PSU decoupling.
The rest, preferably the Wima/Rifa MKP 100nF's and Panasonic FC electrolytics should be sourced elsewhere or otherwise use what you can find, just make sure they'll fit on the pads. For the semiconductors it's each man for himself.
It would be good also a few "pioneers" may experiment early on with the various type of FET's provided for to see if there's any clear winner. The IRFD types are easy to do so with since they fit into a DIP-4 socket, but the SOT-223 packages are for keeps once they're mounted unless you've skill and guts.
For the LTP transistors fast ones would be preferable if fast output transistors will be used, and that's why the original 2SA/2SC ones will do well or alternatively BC546/556 that may work possibly even better.
Hi Mark, just sent you money for 4 boards for dr.Strangelove3 and 2 for me. I feel lucky to know your DIY folks.
Thanks.
Loek
Thanks.
Loek
HI
With out the BOM it would be difficult to look for the parts or order them.
Which schematic we use , or some information about the transistor , mosfet replacement .
I thought we have the BOM like at KSA-50 .
Mark you already built the amp for test , which schematic U used ?
I just want to order the resistors until the sale end at Partsconnexion .
I don't want GB on the parts , I have some Panasonic capacitors and transistors already .
Somewwhere there is a BOM that Pwatts posted. I will have more time tommrrow night to get this stuff posted on the WIKI.
Mark
Mark
- Krell KSA 100mkII Clone
