is it ok if i revive this thread, seems to be far aaway now from the original topic hehehe
i'm planning on buying a K10 for my subs, because my current amp destroyed my LF drivers BTW the drivers are crown JH182. it got destroyed after a day of usage could this be my amp's fault?
I need also a good opinion on buying a good sub amplifier, please enlighten me about CRELL CA20/25 or KEVLER MC2. Please Masters, i'm so confuse about this toys 🙂
I need your expertised and some advice i just bought Beyma 15 inches 750 EAS is posible to put in WSX BOX? also planning to buy CV5000 power amp to drive this and buy 2 more 18 inches may be PA speaker to in this CV 5000,,,or any recomemded power amp,,,salamatz
sir audiomachine if you still have the copy of MB sub zero box pls. send me a copy too..email nilojamisola@yahoo.com .... thanks in advancesir audiomachine can i have also copy of your MB sub zero box i will try to make. email mnvs1969@yahoo.com
Some comments from this site are negative but other said is okay, am also planning to buy but was thinking for other brand.
Anyone give a comment who's tried using CV5000 power amp,,need some inputs from you guys based on your experienced,,,salamatz
Hello fellows. i'm a newbie on building up a small sound system. can i use Crown JH-159 for WSX or folded horn box? if possible anyone who can share me please the dimensions?thank you..
They should be available in any reasonably stocked parts supplier in your Country, they're quite common and cheap fast diodes.
Greetings...!
sir audiomachines...good pm..sir, is Sound standard MA3600 is just the same as theMA3602...what i mean the schematic diagram...? do you have sir schematic of it..? can i ask it from you...thanks in advance..
Hello Guys, do you know where I can get one of these horns here in the Philippines? QSC horn for de250 QSC PL-000446GP Replacement Waveguide Horn for HPR152i 245-625
Harmondson Audio in Cebu city have those kind of horns.
hi to all. does anyone know why my konzert av 302 is creating too much echoing even if the echo volume is off. thanks in advance
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
