konzert av-502A
I guess you have a problem with your main volume potentiometer.
@ sir audiomachines
tiga-silang pala kayo... ako sa dasma... puwede po magtanong..?
wala rin me masyadong alam about audio tech eh... I have a
konzert amp av-502A... napansin ko lang parang hindi synchronized
yung volume nung amp... i mean... bago ko marinig talaga yung
sounds na lalabas sa speaker ay nasa bandang 8 o'clock position
na yung volume knob... yung left speaker side pa lang yun... at
bago ko marinig naman yung sa right side speaker at sumabay ng
tunog sa left speaker ay dapat konting pihit pa... normal ba ito or
may diperensya..? wala namang issue yung speaker and na-try ko
na ring pagpalitin sila... gusto ko kasi pag turn ko nung volume knob
ay sabay na silang tutunog agad... at tsaka isa pa pala... normal din
ba na sa bandang 8 o'clock position pa dapat yung volume knob bago
ko totally marinig yung sounds..? gusto kasi yung tipong nasa 7 o'clock
position pa lang ay sabay na sila dapat tumutunog... not a bigger issue
para sa akin kung tutuusin kasi laging nasa 10 o'clock position naman
ako or mas mataas pa yung volume (mahilig mambulabog heheh) baka
kasi yung abnormality na yun pala ay simula na ng pagkasira nung amp...
para kung kailangan ng paayos ay maagapan ko na agad... already tried
balancing pero ganuon pa rin po... yung left pa rin nauuna at sasabay na
lang after yung right... then oks na... first time user kasi me ng amp and
boxed speakers... pamini-mini compo lang me dati kaya i'm not used to how
music source(cd/dvd/mp3 player), amp plus a pair of big speakers behave..
TIA po...
btw... pair of speakers(konzert kss-12, 450w 8 ohms each).
^_^😉
@dogtag,
sir alvin_alvin is right, the problem is your vol pot, it may have a dirty or a dead spot on the carbon track.
Thanx sir!! and yeah it's more like a dead spot on the carbon track
as what you say (don't know the parts it but i think it's the culprit.).
any advice..? do you know what parts should i replace sir..? or can
i try to spray it with some contact cleaner first..? or better bring it
to a tech..? upss... too many questions.. sorry.. ^_^ TIA!!
@maluphet2000
Here Sir...you may find something useful...
http://constantpressure.blogspot.com/
Magandang araw,
jojo
Magandang araw,
jojo
@all,
anybody using the old jensen imperial folded horn box design in manila? 🙂
I know someone here in our place who is an enthusiast of that huge (I mean way huge😀😀😀) jensen imperial, a potential for a domestic dispute ha ha ha
yes sir, but usually the unit comes; with this functions compressor/limiter/expander/gate. Great for restoring the dynamic range of recorded music, dbx brand comes to mind.
@dj_jojo
sir what would be the correct crossover settings for my wsx sub and mt122 mid tops. i only used analog 3 way bheringer cross over sub harmonic dbx and 31 band eq bheringer. pls help.
@dj_jojo
you should be ok at 125hz...i dont think dbx sub harmonic will be useful.
sir what about the mid-high? y did you say not that the sub harmonic in not that useful i will not soud will? i got 16 wsx and 4 mt122 can u recommend the good way sound processing hock-up.
dbx subharmonic wont be useful kasi your wsx goes low enough, lalo na set up mo na 8 WSXs per side, lakas na nyan,
mid high, would be 2kHz provided your compression drivers can go that low..
experiment, use your ears and ask your companions which sounds good in your settings
16!!!...WOW...now you really don't need that DBX SH...it can damage your speaker due to over excursion.
mid to hi xover...900hz ~ 2khz...it depends on your passive network and Driver Horn cut-off frequency.
Picture please...16wsx...
dj jojo md,
how about your 50cent about post #1405?
WSX is soooooo far far awaaaaaay from L36...
Magandang araw,
jojo
thanks sir jo
i forgot to take pictures when i do blessing and little bit of disco. thats y maybe my soud tech turm down the bass boost of the dbx. and he try to boost the eq from 60 to 120hz. i cant relay so much of ear mid you sentonado. sir did you used spectrum analyzer to set up your eq? my mt122 uses 12inch jackhammer woofer and tdu 500 horns. for the compression driver i used 3.2uf and 5 ohms 20 watts resistor in series.
@audiomachine
@jojo
sir, pls help me buy the right one, i'll be buying 15" plastic floor monitor tommorow, i only have budget at around P5000 to 1 pc and i need to buy 2 pcs. which is 10k more or less... what brand is best for that value; crown, kevler or any other which you would recommend? need your asap response. . .thanks. . any respond from any one?
@jojo
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
