Re: fake op
I have been looking in eleshop several times and have not bought any output devices yet. but I have asked them and they have two types. toshiba and fairchild outputs both 2SC5200 and 2SA1943. they are selling the fairchilds at higher price probably these are originals?
rlg_200 said:hello guy,
fyi, 2sc5200, 2ca1943 absolutely fake if the part number can easy to read. i bought in eleshop raon. when I powered it to my amp my fuse blown. just for curious I cracked it and I found that the die is undersized.
there is one transistor the part number is hard to read, but no idea if it is genuine. according to the store (eglo electronics supply) it is original daw. I dont think so the price is cheap php 90. huh
rlg 😉 😉 😉
So far, the parts I got from Alexan, Deeco, Orient are working good. As far as I know, original power parts are laser marked. Another criteria if a part is fake is its wieght. We can compare it with the datasheet.
gud am to all,
xaudiox,
currently I have some couple left in my drawer enough
for a Leach Low TIM power amp......
I do need more for my next project , maybe when I'm done with the Leach
Ill be in touch.
thanks,
macweb
xaudiox,
Ill be in touch.
thanks,
macweb
crestaudio 9001
hello heinrich,
I the pro8001,8001,9001 which one should i mail to you?
The original Toshiba 2SC5200,2SA1943 has a golden brown marking that can be easily rub off and the metal die is not so shiny. I got mine for 90 pesos each.
Best Regards,
audiomachines
hello heinrich,
Best Regards,
audiomachines
@audiomachines,
could you send me all of above shematics too? thanks, just hit the email button...😀
@audiomachines,
can also have a copy of those sch's. tnx.
@Tony
musta ka na dyan sir sa russia. si ferds to.
@Tony
hi audiomachines,
I already have a copy of the PRO9001......
ok lang😀
what about the Konzert K10 a scanned copy will do.
have you got it.....😉
macweb
ok lang😀
macweb
ESP 1.5K power amp
hi guys,
does anyone built the power amp from ESP (Eliot Sound Products)?
here's the add..
http://sound.westhost.com/project117.htm
please post your comments re this amplifier if you have built it..
thanks
hi guys,
here's the add..
thanks
ok lang, medyo busy sa work...malamig na sa umaga at gabi dito pero sa november pa ang snow😀
balak nilang magclone ng high powered amp sa thread na to, baka makatulong ka sa pag-layout ng pcb?😀
@all,
ferds can help you lay-out a professional looking board for a professional amp using protel software, we can do a group buy of boards from a pcb manufacturing house. FYI, i participated in a group-buy for leach 6 transistor amp and cost was U$11, not bad i would say....
Re: ESP 1.5K power amp
sorry, i have not built this nor do i intend to, afaik, this article was not meant to be taken seriuosly. at this power levels, class G or H would be better, than class AB. but then who's to keep you from pursuing this.
jayrjoe said:hi guys,
here's the add..
thanks
1.5 KW amp
ok thanks tony, maybe you could recommend us here a good class H design which is also fairly affordable.
best regards,
jay-r
best regards,
jay-r
hi audiomachine,
Can I have also a copy of that model? (pro8001,9001). I'm also interested .😉
rlg_200@yahoo.com
thnks,
rlg
rlg_200@yahoo.com
thnks,
rlg
hi ,
I hope I could also help try this:
http://www.schematicsforfree.com/archive/dir/Audio/Pro_Audio/Products
thanks,
macweb
thanks,
macweb
Hi all,
This thread is wandering a bit, but anyway, I hope everyone got through the typhoon ok!
Cheers
Cheers
re typhoon:
fine over here, just the life with no power and water for a few days is a nightmare. but we managed to live through it. 🙂
re ESP amp:
someone at the ESP forums have posted that he built it. can't remember the thread title but it's somewhere in there.....
edit: here's the thread..... the one who has built it posted on the last page.
re ESP amp:
hi,
yes somebody had build it but just +-115Vdc I guess
with some tweakings done
hope to one someday but maybe class H
yet I'm not building anything with higher rails (higher than 100vdc) unless operating
principles are understood.
regards,
macweb
regards,
macweb
my personal choice is that anything above several hundred watts, I prefer to go class D since at those powers, it is very difficult to get huge heatsinks over here. and the power saved by efficiency is greater.
you could say that it is much more difficult to get class D parts here.....but I order them online as kits so there you go. 🙂
hi,
class D?
if only these amps are cheap why not...
its so efficient and very light that delivers huge amount of power
but its price is so opposite
regards,
macweb
class D?
regards,
macweb
hello guys,
sorry for the late reply, what a typhoon we took a direct hit.
sir Tony & xaudiox pls post your email here so that I can attach the crestaudio schemes. thanks.
Best Regards,
audiomachines
Best Regards,
audiomachines
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
