hi audio machines,
forget to ask re the labon power amp, is that 2500 watts 8 ohms RMS per channel?
hello jayrjoe,
Gee man I though your in p.a. work😀 that's one serious home setup
Yes the Labon power amps 2500w into 8/ channel. I would suggest you try one of those bass exciter/ enhancer processors from Behringer.Try also to use heavy guage wiring for your extension cords/ power strips. This amps drew large amount of current. Maybe your 220VAC is sagging, that is why your amp goes into premature clipping, it needs "stiff" 220VAC supply. I think the V12 is rated just like the H3000 1.5Kw at 8 ohms. I'll try to dig some info for you about the Konzert V12 power amp. Yes it is a class H amp.
Best Regards,
Audiomachines
Best Regards,
Audiomachines
hi audio machine,
wow! that so much power for the Labon amps...
can it handle 2 ohms load? worth interesting to see those amps in pictures and action hehehe, maybe too expensive mate. could you please give me their website? made in china also?
yap in the near future, i will upgrade my EQ to Behringer FB6200 a dual 30 band EQ with feedback detector.
then I plan to build the 186 horn or the 1850, maybe the T & T driver would be suitable on that cab, still not sure, im still waiting for the T/s parameters from the supplier. i dont have any gadgets to measure the T/s of speakers.
more power...😀
more power...😀
hi guys,
good morning to all,
anyone who has the T/S parameters for the T&T 18 inch subwoofers?
its a dual stack magnet sub with double spider and with a power handling of 1000 watts rms.
i've asked from the suppliers but got no reply from them yet. maybe you guys have readily available or have measured it thru some your gadgets.
please do share if you have any, i'll glady appreciate it.
thanks in advance.
thanks in advance.
hi audiomachine,
I wonder if you've got plans or measurements for L36
cerwin vega subs
macweb
Tech Stuff Audio Engineering
Dgte. City
Phils.
6200
cerwin vega subs
macweb
Dgte. City
Phils.
6200
hi hienrich,
I got the L36 plans for the cerwin vega 189je II drivers, send me a pm and i will email it to you.
hi audiomachines,
pls let me have it also: roland.ong@vishay.com
i was thinking to build the labhorn 2x12", problem is shipping costs more than the drivers itself.
thanks,
roland
thanks,
roland
ah here
does anyone of you guys know where to get supplies for
extruded heat sinks ?
I mean the ones that we commonly used for our diy power amps.
Me and my store partners need a wholesaler for such.
Well in Cebu, at AC/DC or Tommy's they sell them for more or less
17.50 pesos per inch, the thicker one.
and I think this is just too expensive for a wholesale price.
If ever you guys have an idea pls. include addresses and contact
numbers
thank you,
macweb
numbers
thank you,
macweb
Quick question guys - musically, which amp - Behringer or Konzert? 🙂 🙂
Looking for something that will push maybe 300Wrms/ch into 8 ohms...
Of course, could DIY but transformer, filter caps, heatsinks, casing, output trannies - all add to the cost. Wondering if any of the above brands would make a "nice" base design; reuse as many things as possible though certainly change the circuit topology if needed..
Cheers
Cheers
i have not heard any of these amps, but i understand that the selling point of PA amps is that of power, lots of it...i could be wrong though...
Hi Tony,
Right of course - so can you use a brute and turn it into a ballerina (a powerful one at that?) 🙂
Behringer for example claims the use of Toshiba / On-Semi transistors in their amp. Starting with that as 'base material', maybe a good-sounding amp can be made...
Cheers!
Cheers!
haven't tried konzert amps but I have their compressor/limiter and dual 31band EQ and they seem pretty good for the money.
I have a habit of opening stuff when I arrive with them at home and checked these out. 100% metal film resistors and film caps. 😀
hi,
The Behringer A500 got some good reviews, I wouldn't go for the Konzert amps especially the proamps. I been around playing with these ''brutes'' for some time,IMHO good and economical for p.a. applications only, and maintenance wise to. Lots of cheap power.
Best Regard,
audiomachines
Best Regard,
audiomachines
djQUAN said:haven't tried konzert amps but I have their compressor/limiter and dual 31band EQ and they seem pretty good for the money.
Wow - where do they get parts like that... So sad that Raon doesn't seem to have such things...
Or is there???
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
