@ engel
It would help a lot (the musician) if you could elevate the guitar amps
a bit (i.e.place it on top of the tour case, chair etc. and point the cabs at the head of the musician) that's what happens when the musician can't hear themselves, they'll compete for volume.
@ juancho esteba
you should have try the Martin WSX cabs with the PD1850, just like the L36 but a bit bigger. It is a 7 ft folded horn, while the L36 is around 4ft or 5ft maybe. Hence it throws farther than the L36.
Here is a trick that i do when using the subzero pull down the (-2dB)120Hz,(-3dB to -4dB)150Hz on your 1/3 octave eq this will reduce the "thud" sound. If you really wanna go really savvy with your equipment. You can place a dedicated eq for the lows (post eq) crossover low/(low sum mono if you electronic crossover has this function no use in running the subs in stereo) output => eq=>subwoofer amps. If you are using a loudspeaker management system such as dbx driverack or bbs omnidrive etc. then life would be much easier.
Best Regards,
audiomachines
@ juancho esteba
Best Regards,
audiomachines
Dear Audio machine,
Im a new member here, I just wnt to know what is the best amp to drive a truvox celestion speaker 15".
Thnx
boris
Thnx
boris
sir audio,
last time i was testing my newly built w-bins with 1860, first time i try this low summed,(behringer 4 way x-over)the x-over low left from that day give me headache,sometimes functioning most of the times no low left out from x-over,what would be the possible problem this left op-amp inside left/low or just loose connect sometimes rotating this left frequency low left functioning(parang bumibitaw)
@audio
Sir can you provide me a plan of this MARTIN WSX cab. Will TNT 18AK will perform very well on these cabs. What speaker available locally do you recommend then. Until now i'm still searchin for the best sound quality nf loudness at my own satisfaction.
I have this set up in one settings
1st setting
mixer- Beringher wnyx 1202
equalizer- Peavy 15eq
x over- DBX234XL
2 x CA16 to drive 8 18 incher speakers( 4 crowns1860 and 4 neusch pd 1850)
2 CA08 for crown 1545x 8 pcs per amps
1 sakura 735 for the highs ( 4 x500 watts b3tweeters
Now am currently testing this DBX 120A Subharmonics Synthesizer in an effort to have more boost and refinement on mySubs out put/(i appreciate your comments or inputs on this processor)
The 2nd setting
ORG mixer 8 iputs
compressor limiter- alto BK2
equalizer- Alto 15 band dual
x'over (2-3-4 way)
1 - CA16 driving - 4 neusch pd 1850 in AB36 cabs
1 - Ma 4800 Sound Standard driving 4 Crown 1860 in W bins
1 Sakura 735 - 8 x500 watts Daichi 12" for the mids)
1 Lexus M300- 8 x500 watts Daichi12" for the mids)
1 sakura 2302 - 4 x500 watts B3 tweeters
I have not tried combinining the two settings in one venue yet.
My personal rating ( scale1-10) on my sound system
Loudness - 7
Sound quality - 6
I will appreciate your Comments and sugestions for the improvement of my System. By the way I'm from Cagayan de Oro
1st setting
x over- DBX234XL
The 2nd setting
ORG mixer 8 iputs
x'over (2-3-4 way)
Loudness - 7
Sound quality - 6
Hi guys,
What would you suggest the best 18" speaker for my sub zero and what amplifier is suited to drive this?
Thanks.
Thanks.
hi robotech7,
I saw a lot of these Macrotech Crown Power Amps in the 2nd hand shops in Singapore.
Maybe not good why they throw away?
regards,
regards,
hello
@juanco
hello bai,
where are you exactly from CDO? are you regular in divisoria night cafe?
all the best,
jay
@juanco
hello bai,
all the best,
jay
@jayroe
I am based here in Tablon at the back of Elementary school. I am not a regular in dv soria and have not been there. If you have time today or tomorrow you can see my set up at two different venues. Despite of the rain one of my setting was placed in the motorcross at the front of Netle currently held here in tablon for the barangay fiesta in honor of senor Sto. Nino and the other set is in the basketball court for the battle of the bands today (evening and tomorrow and Saturday Disco). Iwill appreciate your visit here if you are interested to see my settings. Actually I am new in this field and only late November last year that I bought additional audio equipments and some disco lights but there are still lot of equipments lacking nd we are still on the process of refinement through luck na lang bai kun matongnan ok kun dili adjust and i lack also understanding in audio principle . I am a Chemistry grduate trying to combine chemical reaction and music " timplatimpla lang style ko bai murag kape thus I really need you expertise
Please refer to this cell no 09261938230/09168304805 .They are not my number but they will lead you to my number .sorry bai ha at least my number will not be subjected to abuse, anyway i already ask their permission . Please ask my number to them(land line and cell).
Crown_Macrotech
@Asmara14
Hi!
Before, any major/large sound company all you can see on thier towering amp racks are Crown Macrotech or Crest Audio Pro Series & now they upgrading, there's a lot of these amp you can see in a 2nd hand shop but the price is still expensive (high resale value)even if 2nd hand or to fix.
maybe that's the reason why & you can check the price online or on Ebay for new or used.
cheers,
robotech7
@Asmara14
Hi!
cheers,
robotech7
Crown CA850
Hello Everybody!
Does any one knew crown ca850 850 watts its look like crown xti on its front it has blue lcd display which looks like crown xti. Its heavy around 20kg or more. Its only php 18,500 at raon beside stage point. I remorse that i never saw this product before i buy a qsc gx5 last dec. I saw this product last saturday.
Hello Everybody!
software
hEllo.. AudiomachinE ano software ginagamit ngayon? kasi marami na k0 nakikita sa mga s0und system laptop ang gamit nila hnd na cd player...
Good day to everybody.
I would like to inquire where I can buy selinium drivers and speakers locally? Are they available in Raon?
Thanks.
Thanks.
audiomachines:
gud am there.......
reading along the thread, you said that you've set up your sub (L36's)
under the stage.....
any advice on how to do this? because my friend here tried such arrangement and what they've achieved was just the feedbacks from the lows.....
or is it from the type of mics used........currently they're using shure PG series for the kick drums.......
regards
gud am there.......
regards
@hienrich,
aux fed the suwoofer and insert a gate/comp on the kick mic, play with the release, threshold controls to get the desired sound. Hope this helps.
best regards,
audiomachines
best regards,
audiomachines
@audiomachine;
which is best to do the thing here.....
can the DBX 166xl do it....
gud pm there
gud pm there
@hienrich,
that would be good, or if you could find a Drawmer DS501, this is not your ordinary gate, or some Phonic limiter/gate it has a tunable frequency gating.
best regards,
audiomachines
best regards,
audiomachines
@audiomachines;
gud am bro...
where can we buy this DRAWMER DS501( i know this will cost a lot)
or the PHONIC PCL 3200 ?
best regards
gud am bro...
best regards
Gig sa amin,6 Titan 48's (4 loaded with JBL 2226H and 2 loaded with eminence 3015LF).Low mids are 4 omnitop 115 loaded with jbl e140's and 2 omnitop 215 high mids loaded with 4 jbl e130's.Highs are 4 jbl 2446H drivers coupled with jbl 2385a horns.
Unluckylly,I wasn't there...
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
