Kicker zx150.2
Perry,
I re did all the solder connections on the amp (very time consuming)
Amp is up and working 100% flawless.
Im gonna work on the next one in a little while and do the same thing i did to this one and hope thats all that is wrong with it.
Thanks for your help
Ok replaced that part.
Next problem is theres.02 volts on the output of left channel and it has distorted output. I took the preamp board out of the amp then measured still the same .02 volts on outputs.
wondering where to start checking?
Ok Perry i of my friends loaned me his scope. Wondering what do i set the scope to?
And what do i probe? Also the test probe for his scope is junk so i cut the end off a meter lead and stuck it in the test probes spot I need a ground so where do i ground it at?
Ok i set this scope up and tryed it on the gate's for the power supply fets to make sure it works.
This is what i came up with showing you that the scope works.
SO what do i need to probe to check the wave forms?
