Kicker ZX1000.1
I don't have one at the moment, on Monday I will try to get one at the store and check if it is damaged and pins 3 and 8 are grounded. I will upload if it worked, Diodes 205 and 206 are connected directly through the cathodes to pins 7 and 12, I will check if they are not leaking, I hope you have a good night
Very good, I hope you can guide me, today I tried placing the fets in their place and the one thing I got is that it will try to turn on repeatedly, I discovered that pin 16 of the tl494 goes high and that voltage is sent by transistors q7 and q8, I guess something is malfunctioning in the driver card and send it to protection. Greetings Mr. Perry and good night.
Hello, good morning, yes, Mr. Perry, I changed it today for a new one and the amplifier is working like new, everything is perfect without heating, this is the output at 45 hertz already at its limit, very clean
