Kicker KX2 crossover question
I have a Kicker KX2 crossover with the following specs.
High Pass Crossover: 18dB/octave, Variable Frequency (40-300Hz), Low Pass Crossover: 18dB/octave, Optional Low (Line Level) or High (Speaker Level) Stereo Input, Variable Stereo Outputs (5V rms), Signal-to-Noise Ratio: >110dB
How good is the crossover and would it be ok to use in a home stereo system?
Indeed it does.
Also eliminates the hit to audio quality caused by the woofer cones moving at frequencies under what they can reproduce.
The only thing I don't like is that at normal listening levels for nearfield listening, there isn't always enough signal for the powered sub's plate amp auto on to trigger and ever since the plate amp was new, it has had a major turn on thump so I can't just turn the auto on to always on and power the amp on and off unless I get a different plate amp with no turn on thump.
