Kenwood KRC-838
I replaced the belt since I saw it was stretched out .
I will have to see what switch is triggered when I drop a tape in .
With the new belt of no tape is inserted the gears will spin if I drop a tape in the unit the tape with not spin and just keeps ejecting .
Wondering do I need a even shorter belt or what would cause the tape to not spin and just keep ejecting the tape
In pic 1 the pulleys turn if there is or isn’t a tape in it .
Pic 2 the capstan stops spinning when a tape is loaded but the pulleys will continue to turn slowly .
I’m gonna explain this the best I can .
In the pic the black capstan is on a shaft and pulley
If no tape is inserted they will spin along with the gears when I spiny the pulleys by hand or with the motor
If I insert a tape the pulleys will still turn but the black capstan stops spinning all together
The pinch roller is the black rubber wheel. The capstan is the shaft in front of it.
The white nylon disk with a gear around its perimeter, is the take up reel. The take-up reel has a felt clutch on it that allows it to slip as the reel of tape changes diameter.
The pinch roller and capstan should forcefully pull the tape through. Is the black pinch roller turning.
Cassette Tape Transport
