karma line arrays
({ ... the story starts here))
dave tell me if i got this right, im just working out the wiring. i wana get 8ohm. each driver is 4ohm two driver in series is 8ohm?
and to change the watts, do i wire each set in parallel?
im going to need a lot of wire ;)
frugal-phile™
Joined 2001
If you use 32 drivers in the array, wire 8 in series (32 ohm) & pararallel the 4 sets and you end up at 8 ohms. Or wire 4 in parallel (1 ohm) & series the 8 sets.
Power handling is 32 x power handling of 1. Efficiency is about 14-15 db more than a single.
dave
you can see pictures of the amps on my webpage under projects.
but my webpage is down i had to turn the server off, do to the security guard uses the same room it can get hot in there.
two weeks left of the school year for college, partys bigtime theres a kegger next door;)
