Karlson "K-tube" in Hobbyhifi (does anyone have this issue?)
A scan of the article.
Reactions: JS95
Aczern,
Wow! Thanks for the scanned article. Truly fascinating. The performance looks quite good. At Freddi's recommendation (and he got me a CD to use) I have tried the K tube tweeter and it is absolutely smooth sounding and has a very wide and uniform polar pattern. The sound is beyond any intuitive sense that one might think it should sound like. It has the wide dispersion of a good dome tweeter (even better) and the high sensitivity of a compression driver by without the harsh spitting sound of a CD.
I can't read German but am guessing this is a field coil driver and that box is the could voltage source?
2nd order harmonics are high at around 1% throughout but higher orders are low(ish).
Probably because the coupler appears to be relying on diffraction which is something other horns try very much to avoid.
And yes it is a field coil driver and the box on page 3 is the transformer supplying it.
Thank you aczern for the article. Not exactly a straight response, but It can be worked with. Not much Hf extension. What concerns me the most is the waterfall plot around 8-10KHz, unfortunately it is problematic on all compressiondrivers I know. but we dont know what is caused by the driver and what is caused by the tube. Interesting....
hi aczern - thank you very much for the article. Here's a sound-file/"video" of generic crossover hooked up to my K18 - it has a clone of a ~1966 Karlson X15 K-tube ~7.25" long and 1.875" ID mounted above the 18" EV woofer. There's a short angle sliced tube at the throat. A later X15 K-tube appeared to be about 1.25" diameter tubing - I don't remember the compression driver as its been years since I've opened this cabinet. It has a curved reflector and 4 - 1" dowel rod struts on the wings.
its possible I think to get good sound with the X156 approach where the K-tube is mounted in the front chamber.
I have over a ton of horns but still love the Ks best 😀
BTW - when using a K-tube on top of a cabinet - I would consider experimenting with cardboard baffles
at the driver exit plane to smooth the low end and make a better match to the bass unit. K-tubes have a nice
high vertical window and seem to match midbass and bass Karlson couplers nicely. Transylvania Power Company
was the first manufacturer I saw to use a K-tube on top of a cabinet. That size at ~5.3" long, 1" ID and a half-ellipse
slot works well and easy to make of pvc/abs or those with good tools, brass or copper pipe.
K18
https://www.youtube.com/watch?v=XYsdJZA7coE
8 inch K-coupler topped with Transylvania Power Co. "The Tube" - that Dayton 250p driver has
high distortion - i need to rotate its coil and do some measurements - it sounds ok but is less sensitive
than a P-Audio BMD440 and the 440 measures much cleaner on this tube
https://youtu.be/T71pRwTGfuc
here's IG81's Transylvania Power Co. "The Tube" with a BMS 4550 - don't think the swamping resistor would be needed with 2nd order highpass nor with most compression drivers. A piece of PVC pipe will do about as well. I would expect a baffle at the compression driver's exit plane to help reinforce forward radiation on the low end. Experiment with cardboard, then once satisfied, make a nice looking baffle,
