Jung/ALW reg issues.
AndrewT said:
I cannot see any connections to ground for pins/components in that post37 pic of the ground plane .
I cannot see the right gnd to left gnd connection either.
No, I solder the components directly to the copper, the purpose of the PCB was to show that the copper is SPLIT just right of the opamp. The copper on the left has all power ground soldered to it and on the left all the Vsense parts.
This PCB is un drilled and obviously has nothing present on it, ie no join between left and right copper.
janneman said:
Well, so far we have no clue what the problem is, don't we? Why going around in circles speculating (unless you enjoy wasting time as inefficiently as possible)?
Just measure, and get it fixed.
Jan Didden
Yes it seems like I have more then enough to look into now, and information to read. I think my first port of call is to try powering the opamp separately (this is easy to do) and see if that solves anything.
Ill get back to you all once I've tried everything.
And once again thank you for your time.
