John Curl's Blowtorch preamplifier
Simpler design different model (AU-919).
Shunt feedback rather than series feedback 😉
I got some 2SK170's from someone on the forum and ran a quick comparison with the BF862. Not perfect but not too shabby for something you can pick up for 15 cents. In headphones I couldn't really detect an important difference. The comparison is at 1mA Id and actually the 2SK170 has a hint of G-R noise but a little less 1/f. The flat band is ~1.2nV.
john curl said:
Dated designs, somewhat impractical with the availability of today's devices. Why not a transformer, instead?
Why not ?? After all what are we dealing with here but a diamond tip riding through a plastic groove which hopefully has minimal crud, minimal warpage and can hopefully maintain its elasticity for the next play 🙁 Then there is the turntable itself a concept which dates back to Edison's first design 🙁
Maybe this whole thread is just academic 😉
SY said:
You're missing something. The 2M resistor along with the single cap keeps the DC on the two second stage grids equal and elevated in the face of any offset in the DC of the first stage plates.
edit: What are the tubes? Something like a 417 or 6HA5?
Yes you are right 😉 You get differential mode operation without the problems of DC imbalance 😉
>Yes you are right
You can do the same with SS.
But you have to embrace capacitors.
I would venture to say that a part of
the 'magic' of tubes is that they are
usually capacitor coupled and therefore
each stage can run optimumly biaswise
without consideration for subsequent
or previous stages.
