john curl said:BandAid? Eureka!
I have no idea what that comment meant.
Oh well, off to dinner.
Steve Eddy said:
So no one has ever had any noise issues with commercially produced gear due to he ubiquity of 3 pin IEC power connectors and power cords and the chassis leakage currents they cause?
Right. So how does that counter my statement?
Steve Eddy said:
Yes. God forbid sound should play any role in audio.
Instead of getting off in our listening rooms with good music, we should be getting off in our bathrooms with a graph in one hand and our manhood in the other.
Erm, what kind of music do you listen to??
reminds me on the point about where Ben franklin got it wrong when he labeled the polarities.
The follow up is: how do you make a balanced cable work best?
Ba-da-boom ba-da-bing.
Physicists and EE's routinely use the opposite definitions of polarity.
He didn't get anything wrong. It's just a sign convention, nothing more. If you reverse all the sign conventions in circuit analysis you get the exact same answer.
Sort of. When it comes to 'grounding' or 'shielding' it becomes a different matter. Einstein mentions that too. Celestial Mechanics does not -quite- work, unless you go to that thing he said about 'possibly having the sign wrong'..then it works..and the planets no longer fly out of their orbits. Whew! 🙂 A ground tends to have a reactive mass, so proximity becomes a critical point. So layout becomes an exercise in 3-d geometry and how it relates to the dynamically surging AC fields/mass around each device/trace/wire/board/chassis/etc. As well, the entire dynamic considerations of the signal are also expressed in the ground path (after all it IS a 'return' to a large degree, depending on the gear type), which should have similarity to the signal path, in scope and layout. Not less, and certainly not more.
For the record, I have all the respect in the world for John. I have stated several times that I think the stuff he did in the 80's is probably all anyone would need. Sometimes we're a couple of old coots arguing over ideas that we have become married to and I admit I'm not that tolerant of imprecise thought. So let's get back to circuits.
john curl said:Mike appears to be clueless!😕
That I doubt, just a different point of view.
But I stand by my comments even if ya'll think it's impossible based on your experience. Remember the rabbit hole.
john curl said:The '80's are the past, but most of you have not caught up to that point, yet.
Actually, in the 80's I was a starry eyed clueless dreamer. Then reality set in.
While I may not have the focus and passion you have for the intricacies of the topography and device characteristics, I put the same amount of effort into understanding the environment that a circuit operates in.
Now that were in the new millennium, my experience allows me to build very sensitive sensor applications that function flawlessly in environments that make audio look like a child's playground. Building block electronics executed properly, I think.
Don't ask questions, attack! That’s how we all learn.
john curl said:Transformerless? I sure hope so.
But of course, no bandaides needed.
MikeBettinger said:All controllable through proper grounding layout. No noise needs to circulate through the signal path.![]()
Three prong power cords can introduce issues which go beyond internal grounding layout.
The hot lead, which by code is to be connected to the equipment chassis through the most direct means, capacitively couples to the safety ground creating chassis leakage currents.
If the voltage drops across the power cords of two interconnected pieces of equipment are not of the exact same magnitude and polarity (which would cause them to cancel), then an AC voltage potential between the two equipment chassis is created resulting in interchassis currents.
And because of the non-zero resistance of the ground leads of the interconnects, the voltage drop across it appears at the input of the downstream component.
Bandaide approach to solving the grounding issues. 🙂
No, the current mode interfaces used by Krell haven't anything to do with grounding issues.
se
G.Kleinschmidt said:Right. So how does that counter my statement?
Your original post seemed to imply that ground-related noise issues were pretty much the province of amateur DIYers. I was simply pointing out that commercial gear can be problematic as well.
The kind that I enjoy.
se
MikeBettinger said:But of course, no bandaides needed.
Actually when I brought up transformers in this thread, it wasn't in the form of any sort of band-aid. But rather their use as a passive, balanced, differential input/voltage gain stage.
se
1) But these currents do not have to circulate in the circuit grounds. They only need to be terminated back to the power transformers/supply references of the two components. Control this loop and the negatives are minimized.Steve Eddy said:
1) If the voltage drops across the power cords of two interconnected pieces of equipment are not of the exact same magnitude and polarity (which would cause them to cancel), then an AC voltage potential between the two equipment chassis is created resulting in interchassis currents.
2) And because of the non-zero resistance of the ground leads of the interconnects, the voltage drop across it appears at the input of the downstream component.
3) No, the current mode interfaces used by Krell haven't anything to do with grounding issues.
se
2) Only if you allow it to.
3) My comment was based on the way the reference was presented; as a fix for grounding issues. If I interpreted it wrong, my bad. The rest still stands.
se
I realize this, but the conversation turned to the isolation aspect, which is what I was responding to.
Mike.
I just bought one of these:
http://www.radioshack.com/product/i...kw=microphone&kw=microphone&parentPage=search
It will not drive my PC 'record' to enough level .
Is there a possible 'transformer' solution ?
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/3303039A_PM_EN.pdf
- John Curl's Blowtorch preamplifier
