John Curl's Blowtorch preamplifier
I find it curious that anyone should even try to advance the idea of phase shift between a drum and the mic recording it as a crucial point. Just how far away do you place the mics from the drums, anyway? At 1100 ft/sec, I don't think you're going to find a significant shift between the drum and the mic, particularly since we're mostly talking about kick drums, i.e. instruments with dominant low frequency content, hence long wavelengths. And your mic is how far away from the drum at the fundamental frequency? And just how many degrees of phase rotation does that work out to?
I don't know about recording conventions in European studios, but over here the mic is generally as close to the drum head as it can get without actually touching it...not thirty feet away.
To throw up your hands and wail "It's all too murky. I won't even try!" is rather a cop out in my opinion--particularly since phase is so easy to preserve electronically, and easy to make adjustable for the user.
No, it's not the single most important parameter in the world, but why not at least default to non-inverting designs even if you don't put in a switch?
Jeez.
Grey
KSTR said:
[snip]
I'm not a aware of much pro gear, ranging from mic-pre's, mixing desks, outboard devices, to the final ADC, master recorder or vinyl cutter that explicitely mention preserval of absolute polarity. Maybe it is considered self-evident that it does so, no need to state that then, but I'm by no means sure that this is a fact.
[snip]
- Klaus
Hi Klaus,
Forty years ago, I worked for Phonogram, a daughter company of Philips (later of DGG). There, they always checked the polarity of their equipment.
Edmond.
Misinterpration again, it seems.
I bet Jan actually meant with "phase relationship" polarity (once again) of the dominant attack (which depends only on how the drum is miked, take a tambourine as the most ambivalent example), not any phase shift within the waveform due to dispersion or the like.
- Klaus
I think that many here would do well to 'get up to speed' when discussing 'absolute polarity' As I said before, many engineers have looked at the problem over the last 40 years, and their papers should be studied first, before some sort of intelligent debate can be made on the subject.
The second alternative is to just TRY it. Yes, just trust your ears. IF you find it a real problem for YOU and your audio playback system, make sure that you can easily and effectively reverse phase, without adding or subtracting too much from your system. IF not (like me) then relax and enjoy the music.
I have a story on absolute phase audibility topic. Few years ago we compared one of my preamps to another units. My was inverting, so I always reversed speaker cables. During afternoon I left the audience and they were exchanging preamps themselves. After I returned they told me something was wrong with the sound. They did not reverse speaker cables for my preamp, of course. So I reversed the cables and everything was OK again. So the people who did now nothing about absolute phase heard the difference and classified the problem.
PMA said:
I do not see any reason to argue with people who do not have enough own experience.
Point taken. I think I'll leave those who wish to ignore the topic stew in their own juices.
john curl said:
I agree, PMA. Allpass tests (phase shifters) do NOT work! It has been explained (barely) in the Schroeder paper that I cited from 1975, why this is so.
Assuming a digital all-pass, then the idea's a non-starter, at least for a signal in the analog domain.
Assuming an analog all-pass, they have bandwidth limitations, something I'd rather avoid.
Either way, you've got more circuitry in the signal path. This is supposed to be good for the sound quality? The cure is worse than the disease.
Getting the phase right is the ideal thing to do at all frequencies, but I regard it as more audible and important at low frequencies where it's less affected by small incremental placement issues.
Grey
I've known that absolute phase can be audible since I was about 16.
Who here, so far, has argued that the audibility of absolute phase is an impossibility?
Who exactly (to quote somebody else) is stewing "in their own juices"?
