John Curl's Blowtorch preamplifier
jc-80 input
I hope it's allowed to post a jc-80 question.
When i look at the design i see some servo regulation at the right half of the j-fet pairs(the - input) so i suppose that this preamp needs a unbalanced source.
Can i connect that source with the + input only?
With some balanced preamps needs the - input to ground.
Johan.
unbalanced use of jc-80
Dear Mr.Curl,
Thank you for the fast response and new hint, but my first question is stil open.
I use unbalanced sources so what to do with that (-)input?
Shorting to ground disturbes the servo i guess.
Resistor to ground? or ... nothing?
B.t.w what are the specs of this legendary preamp?
Thanks again,
Johan.
Modified JC 80
… Just a global attempt to update the JC80 for fun, with today’s components.
Resistors values are changed to fit the Irf devices requirements and to reach a 20kHz bandwith in open loop.
The 2SK389 and 2SJ109 can be replaced by the 2SK170/2SJ74 of course, but also by other ones as suggested by JC, in this case R2/R3/R14/R15 must be adjusted. In my case the SK 389/SJ109 Idss value is 10 mA. Mosfets Idle Id is 50 mA. I changed the original input stage arrangement for this preferred one. It just a starting point, probably the MASTER will see some possible improvements. I didn’t build it, some measurements with real devices could lead to various modifications .
Gain 12dB.
Zout 50R per side.
The DC servo could be something like the one I post about the Blowtorch in this post
Richard, another "modification":
