Ironhardware, you are VERY lucky that you don't have a 2200mk1, because I would have you pull out the AD712, in the audio path, first thing!
Well the improvements to the 3500 made a substantial difference. Why don't you pull one of those ol broken ones out and hop it up?
Be sure to take good notes and post them for me.
"I wonder" where I can get some specifics on modding the 2200.
Matt
Matt
Hey JC while I have your ear, the left channel on the 3500 is not heating up as much as the right, Phil H has sent me the info on replacing the fuses with the thermal switches, and wants me to check the voltages across the emitters. Do you have any suggestions?
john curl said:Demian, you gave us quite a handful, and not enough REAL input to make intelligent discussion. We need to know about every part. Sorry, but I certainly can't help further.
I'm not entirely clear on what you want to know. You have the schematic and a detailed photo of the parts and layout. I'll be happy to fill in more info. as best I can.
Listening to the output of the differential output is best described as uninvolving. Since changing the components would be a little risky (surface mount etc. and not mine) I connected to the output of the current to voltage converter. It was a little better.
I hate to work on audio equipment without a tech, and I can only afford a tech when someone else pays him, ultimately. At this time, I share Demian's tech. Good guy.
I prefer a tech and an advisor, but I try to follow along.
Thanks again JC, I'll post my progress. If you can point me to any specific mods on either the 3500 or the 2200ii I do appreciate them.
Matt
Matt
On the 2200, you might first remove all the extra caps across the power supply, NOT on the board.
I'll take a look at that, I believe we did that on the 3500 as well.
Will the 2200 like the hyperfast bridges?
lineup said:
I think I have to check out that Charles Hansen investigation.
Subjective matters are a bit more difficult to measure than resistance or some different sorts of distortions, for example.
Sound impressions or what people can visualize in a painting, colors
are such things.
We often have rely on statistical analysis and so count result with probability factor.
100% sure = 1.0,
because from stastistical probabilty the possibility of just chance/guessing is zero.
Another member, 'Gedlee' have done one reserach, much to prove how good his spekers are.
He also suggest a special method a scale for how we experience distortion.
Gedlee is a nickname, short for Earl & Linda, who performed some investigations.
Member profile:
http://www.diyaudio.com/forums/member.php?s=&action=getinfo&userid=31488
Sound Quality
Distortion Perception
http://www.gedlee.com/distortion_perception.htm
Here are some results and plots / diagrams:
http://www.gedlee.com/results.htm
You can freely download his findings and description on the method he used, together with another researcher.
/regars lineup
Thanks for the links, interesting. Though, creating a new metric for distortion that corresponds better to how we hear, is kind of a different subject than blind testing.
scott wurcer said:
One problem I have with these tests is the editorializing, phrases like "everyone in the room" etc. show to me a bias and lack of objectivity equal to the Audio Critic mindset.
Well, I know people tend to put their research in the most postive light. Especially when presenting it to the DIY audio attack crowd. I'd like to see some well documented extended listening blind testing with an objective observer present. I can dream. But some things Charles Hansen said about the importance of experience and familiarity, definitely fit with my experience and what I know about how we hear. And I agree with his testing method for the most part.
I mean when you've dealt with the kind of sound senstivity I have for 10 years you learn some things. You have to know how to make progress and if you don't you go backwards. The ear is extremely senstive to an increase in sounds we have aversion to. Every sound is different. As to what is and isn't audible? I think blind testing can work if it takes into account that sounds are learned.
open loop transfer function
Hi John,
I don't think the open loop transfer function is simply ignored by most of us, neither by those who apply a lot of NFB. This is because you can't 'hide' all non-linearity by increasing NFB ad infinitum without violating stability criteria. So, at a certain point, it's much easier to linearize the open loop transfer function instead of all the hocus pocus to stabilize an ultra high gain NFB loop.
Nevertheless, I don't see any disadvantage by doing both, i.e. linearizing and applying moderate NFB.
BTW, if NFB really 'hides' the shortcomings of a nonlinear open loop x-fer function, what's the problem anyhow?
(In my vocabulary, 'hide' means not only you can't measure it, but also you can't hear it)
Edmond.
john curl said:[snip]
However, the open loop LINEAR TRANSFER FUNCTION is now often ignored, because feedback HIDES the open loop characteristic. Is this OK? What do your ears tell you? Ever listen for yourself?
Hi John,
Edmond.
My pre openloop distortion:
http://web.telecom.cz/macura/thd_olg.png
(John likes to patronize, that's just him 😀 )
What amazes me, how people ask the same questions, over and over. Most IC designs, for example, have fairly lousy open loop transfer functions.
What Charles Hansen and I concentrate on is the open loop transfer function, and how to improve it. This is most important to us, because we have found that to rely on negative feedback to hide it or convert it to another form of distortion isn't normally that effective, when we are making top designs, at the level where we compete with each other. It is like F1 racing vs stock cars. There is a difference, although most people are not aware of it. One important approach is TANH that Scott Wurcer put forth, through the work of Barrie Gilbert. Does anyone have ANY idea of what we are discussing? What are the upsides, and what appear to be the downsides. That is but one. Now, PMA, as well as many other first class designers, tries as hard as anyone, to generate a first class transfer function. However, many more try to just add more feedback. This is why it needs discussing.
NFB
WHO?!
[snip]
IC designers. Most people are not very sophisticated at the level that Scott, Charles and I try to operate at. That is why we are world famous designers.
- John Curl's Blowtorch preamplifier
