minor correction that didn't post:
would best read:
the headphones ought to sound no better or worse than any other reasonably good electromechanical interface to the ear, certainly not "bad"!!
dunno why the edit didn't post...
_-_-bear
the headphones ought to sound no different than any other reasonably good electromechanical interface to the ear, certainly not "bad"!!
would best read:
_-_-bear
Okay i'll try & precis what I lost
John, this is to Joshua.
Speakers & headsets are affected by 1st order effects, classic newtonian physics,Electronics uses these things multiplied by each other,how does a feedback resistor alter whats already happened,& all that.
look I wish I could type faster.
Max
Max
Re: Okay i'll try & precis what I lost
Others are maybe more charitable.
i think you are simply pissed.
albin said:John, this is to Joshua.
Max
Now that I clearly know what the question is, let me try to address it.
Back in 1971 or so, three audio designers got together and asked the same question. We did not have the answer ourselves, but we thought that the great Richard Heyser could answer it for us. So we went to see him, personally, and asked him this question. He didn't have a direct answer either, BUT he pointed out the limitations of our measurements, the problems with ANYTHING with global negative feedback, an how he was developing a different measurement process that might resolve at least some questions.
We went away, not completely satisfied, but hopeful. The rest is history.
john curl said:Caps can sing. Just not very well,
Exactly. Not only caps, but also power transistors and power resistors.
If you find them too revealing, the HD650:s might suit you better. They sound very good and are more made to enjoy music than being a tool for studio musicians.
Sigurd
Sigurd
scott wurcer said:
I forgot to mention that I have Sennheiser HD-600 head phones and a pure class A driver for them. Isn't that OK for hearing small things? Frankly they are too revealing and I find something wrong with just about everything through them.
Re: can anyone tell me
Very off topic, but the black dot means you have posted in that thread.
albin said:What the black dot on the new post old post things means,my head's full of propellers interacting with each other.
regards
Max
john curl said:NOTHING is benign. However, we seem to be able to tolerate a fair amount of distortion from speakers or headsets that we usually would condemn in electronics. Why?
45/2A3/300B type SET amps produce distortion levels not dissimilar to
speakers. They are not only tolerated but revered, and I hate to admit
it - but they can sound very very good!
T
Partial answer:
Most speakers are symmetrical mechanical devices and good speakers - used within their design limits - therefore produce mostly even order distortion which we can tolerate easily. It's subjectively sort of like tape hiss or groove noise, only less obtrusive.
We don't easily tolerate odd order distortions, especially higher order, and they are produced more easily by electronic devices and reproduced faithfully by good speakers.
Also, since a good transducer will consistently produce the same errors at any given input level, we become acclimated to it's sound and thus an aberrant signal produced by electronics has novelty which we may notice in some fashion. So in the end, even even order distortion from electronics may get noticed - folk will say an amp sounds "warm", for instance, compared to another played on the same speakers.
T
T
Not everybody reveres SET power amps.
A
FrankWW said:Partial answer:
[snip]
Hi Frank,
Apart from the question whether speakers produce more even harmonics than odd, any symmetrical system produces odd harmonics.
Regards,
Edmond.
Joshua_G said:I find it amusing how lesser ones feel the need to put down greater ones on order to feel good about themselves.
I tend not to think in terms of lesser and greater, I assume everybody is equal amongst equals. Which means all would be treated equal as well. Which means that when I ask for engineering info from those that profess to be engineers, I'm not treated as the village idiot by so-called 'greaters'.
But it's a temporary problem anyway. Those so-called 'greaters' do a great job to cut themselves down to size with almost every post here.
Jan Didden
Jan Didden
By what criteria they "cut themselves down to size"?
- John Curl's Blowtorch preamplifier
